Cisco 3825 router | need to add Ethernet module
musthafa786
I am having Cisco 3835 with 2 builtin Gig ports , now We need to add two more Gig ports additionally , which Ethernet module would be recommended (model) ?
Musthafa.
5 Replies 5
Richard Burts
Musthafa
I would suggest that the HWIC-2FE would be very good for your requirements. You can use this link to get more information about it
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd80581fe6_ps5853_Products_Data_Sheet.html
Rick
Rick
Please also see HWIC-1GE-SFP supported on 3825
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd8016be8d_ps5949_Products_Data_Sheet.html
*** Do Rate All Helpful Posts***
Jawad
Thanks Rishard and Jawad for your info,
Is it possible to get copper Gig port HWIC (operating at 10/100/1000 Mbps)  on 3825 router ?
Musthafa
You can Purchase GLC-T= Copper Module with this card.
*** Do Rate Helpful Posts***
Jawad
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I just want to mention, a 3825 doesn't have the performance capacity to fully support even a single gig interface let alone four.
Knowing this, this might be a reason to go with the dual FE routed ports as Rick suggested.
Another alternative, would be use subinterfaces on a built-in gig port to a VLAN capable switch.  (NB: or you might Etherchannel your two built-in gig interfaces and use logical subinterfaces on that.)
