Cisco 3825 routing
autohotline1
I currently have a 2811 with 3 fe ports.
I have a 3825 that has 2 built in gb ports, what card do I need to add another gb port. A WAN card is more expensive then a gb card, does it have to be a wan card? These are all RJ45 copper connections
I want to duplicate what I have below with the 3825.
Any help would be appreciated,
Thanks in advance
interface FastEthernet0/0
 description CONNECTION TO SERVER SWITCH
 no ip address
 no ip mroute-cache
 duplex full
 speed 100
 no cdp enable
interface FastEthernet0/0.10
 description SERVER SWITCH 0/24
 encapsulation dot1Q 10
 ip address 192.168.0.254 255.255.255.0
 ip nat inside
 ip virtual-reassembly
interface FastEthernet0/1
 description CONNECTION TO XXX NETWORKS
 no ip address
 no ip mroute-cache
 duplex full
 speed 100
 no cdp enable
interface FastEthernet0/1.100
 description INTERNET
 encapsulation dot1Q 100
 ip address 210.182.72.2 255.255.255.252
 ip nat outside
 ip inspect fwout out
 no cdp enable
interface FastEthernet0/1.4023
 description OTHER LOCATTION OFFICE
 encapsulation dot1Q 4023
 ip address 10.10.10.1 255.255.255.252
 ip nat inside
interface FastEthernet0/0/0
 description CONNECTION OFFICE SWITCH
 no ip address
 no ip mroute-cache
 duplex full
 speed 100
 no cdp enable
interface FastEthernet0/0/0.20
 description OFFICE SWITCH 0/24
 encapsulation dot1Q 20
 ip address 192.168.1.254 255.255.255.0
 ip nat inside
Julio Carvajal
This one should do it :
NM-1GE
One-port Cisco Gigabit Ethernet Network Module
Jcarvaja
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
