Cisco 3850 ip Nat
katheer4u
Good day
can I do the IP nat on cisco 3850? Please advise me thanks
Vlan 10
192.168.1.1
Vlan 2
192.168.2.1
access-list 102 permit tcp host 192.168.2.169 192.168.1.169 0.0.0.255
ip nat inside source list 102 interface Vlan 10 overload
_________________
cisco 3850 information
Cisco WS-C3850-48P
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.06.04.E RELEASE SOFTWARE
_____________
License Level In Use: ipbase
License Level on Reboot: ipbase
Evaluation AP-Count: Disabled
Total AP Count Licenses: 0
AP Count Licenses In-use: 0
AP Count Licenses Remaining: 0
___________
# show ip nat statistics
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Outside interfaces:
Inside interfaces:
Hits: 0 Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 0
Dynamic mappings:
-- Inside Source
[Id: 4] access-list 102 interface Vlan10 refcount 0
3 Accepted Solutions
to my best knowledge, the 3850 does NOT support NAT. The commands are available, but don't apply to the 3850.
TJ-20933766
Unless there has been a change that I'm unaware of, Cisco switches do not do NAT. This feature is only available in routers and firewalls.
Giuseppe Larosa
Hello @katheer4u ,
this is one of the results of unified CLI parser in IOS XE the commands may be present, but a Cisco 3850 does not support NAT.
NAT is supported in Catalyst 6500, 6800 and likely on C9500 or C9600 and on routers and firewalls as noted.
Hope to help
Giuseppe
9 Replies 9
TJ-20933766
Giuseppe Larosa
Hello @katheer4u ,
Hope to help
Giuseppe
Leo Laohoo
Some version of 16.12.X supports NAT on the 9300:  CSCvp78589
Catalyst 9k switches will support NAT starting with 17.X.X.
ioannis.siozos
Perhaps this is an old  post but i want to confirm that the c3850 supports NAT
NAT is not available on the 3850. I think the commands are there, but the functionality is not.
It was tested today and it works fine , also you can see the nat transaltion table and ofcourse that traffic flows
The code that i have on the switch are 3.06.06E
I wasn't aware that it works with that code ! Good to know, thanks for sharing.
It is the code i have tested
Glad that i helped for feature tests
