Cisco 3850 Protchannel
nsonythomas
Hi Guys,
The following commands are not working in my Catalyst3850
Router(config)# interface port-channel 1
Router(config-if)# lacp fast-switchover
Router(config-if)# lacp max-bundle 1
Router(config-if)# end
Currentely the switch have 03.02.03 SE IPBASE .
Awaiting your reply
Sony
LJ Gabrillo
Level 5
Level 5
What do you aim for?
LACP config only requires
#interface range g0/1-2
  #channel-group 1 mode active
#interface port-channel 1
  #switchport mode [access/trunk]     -configure as desired
Thanks for your reply.
I have 2*1G(fiber)  portchannel using LACP from a third party switch to cisco 3850 - and the problem what I'm facing is when one of the link fails the port channel goes down and takes 7-8 timeouts to come up. I wanna avoid that situation.
Hope you undestand the issue.
Cordially,
Sony
You might want to refer to this post: https://supportforums.cisco.com/discussion/10853161/etherchannel-lacp-fast-switchover
