cisco 3925 spe200 router rommon issue
jkay18041
Level 3
Level 3
I have a Cisco 3925 spe200 that has a password on it and I'm trying to remove it. When I try to break at bootup into rommon it shows this
Total memory size = 1024 MB - DIMM0 = 512 MB, DIMM1 = 512 MB
CISCO3925-CHASSIS with C3900-SPE200/K9 with 1048576 Kbytes of main memory
Main memory is configured to 72/72(dimm 0/1) bit mode with ECC enabled
Readonly ROMMON initialized
Booting c3900e-universalk9-mz.SPA.152-4.M7.bin ...
[BREAK]
monitor: command "boot" aborted due to user interrupt
autoboot: boot failed(boot flash0:c3900e-universalk9-mz.SPA.152-4.M7.bin), restarting...
It does this over and over. I then took out the flash card and put it in my computer and imaged it then deleted all the files off of it except the IOS image. Same thing and when it boots there is still a config.
Any ideas on how to get rid of this autoboot and get into rommon?
Julio E. Moisa
Try these steps, it should go to rommon:
http://www.cisco.com/c/en/us/support/docs/routers/2800-series-integrated-services-routers/112033-c2900-password-recovery-00.html
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Predrag Jovic
Level 3
Level 3
If break does not work, try one of other key sequences - Standard Break Key Sequence Combinations During Password Recovery
If all these methods fail to properly send a break, retry the procedures from a different terminal or PC platform.
