Cisco 3945 router with 48 port switch service module
zzbronski
I have been trying to configure a new 3945 router with a 48 port switch service module installed. I am able to connect via console and configure both the router and the switch modul. However, at the end of the day I write the config to the router and then when I come in the next day, the entire config for the router is gone and it is back at rommon. I do a reset and it loads the IOS fine but the config is gone. First of all, I want to know why it is rebooting itself and going back to base config settings. If I can get some help on this it ould be appreciated. I also keep getting this message shortly after reloading router.
Oct  3 18:34:13.191: %ETHSW_SM-3-ILP_RECOVERY_COMPLETE: Time taken for recovery after reload = 300 seconds.
See log below.
Log Buffer (8192 bytes):
Jan  2 12:00:01.559: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3900 Next reboot level = ipbasek9 and License = ipbasek9
Jan  2 12:00:01.607: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3900 Next reboot level = securityk9 and License = securityk9
Jan  2 12:00:01.651: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3900 Next reboot level = uck9 and License = uck9
Jan  2 12:00:01.695: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3900 Next reboot level = datak9 and License = datak9
Oct  3 13:06:16.619: %IFMGR-7-NO_IFINDEX_FILE: Unable to open nvram:/ifIndex-table No such file or directory
Oct  3 13:06:18.447: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Initialized
Oct  3 13:06:18.471: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Enabled
Oct  3 13:06:27.679: %PVDM-6-UNSUPPORTED: Codec G.723 is not supported on PVDM3.
Oct  3 13:06:35.647: IOS-WAAS(waas_dma_get_mem) (PRO): Dimm0: 2048MB, Total Size: 2048MB
Oct  3 13:06:35.647: IOS-WAAS(waas_dma_get_mem) (PRO): Dimm1: 2048MB, Total Size: 4096MB
Oct  3 13:06:35.647: IOS-WAAS(waas_dma_get_mem) (PRO): Returned size = 4294967296
Oct  3 13:06:40.131: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
Oct  3 13:06:40.131: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
Oct  3 13:06:40.131: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
Oct  3 13:06:40.131: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
Oct  3 13:06:40.131: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to up
Oct  3 13:06:40.131: %LINK-3-UPDOWN: Interface SM1/0, changed state to up
Oct  3 13:06:40.131: %LINK-3-UPDOWN: Interface GigabitEthernet4/0, changed state to up
Oct  3 13:06:40.855: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Oct  3 13:06:41.131: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
Oct  3 13:06:41.131: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
Oct  3 13:06:41.131: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
Oct  3 13:06:41.131: %LINEPROTO-5-UPDOWN: Line protocol on Interface SM1/0, changed state to up
Oct  3 13:06:41.131: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/0, changed state to up
Oct  3 13:06:42.131: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
Oct  3 13:06:42.131: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
Oct  3 13:06:42.131: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
Oct  3 13:06:46.467: %LINK-5-CHANGED: Interface GigabitEthernet0/0, changed state to administratively down
Oct  3 13:06:46.567: %LINK-5-CHANGED: Interface GigabitEthernet0/1, changed state to administratively down
Oct  3 13:06:46.715: %LINK-5-CHANGED: Interface GigabitEthernet0/2, changed state to administratively down
Oct  3 13:06:46.915: %LINK-5-CHANGED: Interface SM1/0, changed state to administratively down
Oct  3 13:06:46.915: %LINK-5-CHANGED: Interface GigabitEthernet4/0, changed state to administratively down
Oct  3 13:06:46.915: %LINK-3-UPDOWN: Interface SM1/1, changed state to up
Oct  3 13:06:46.915: %LINK-3-UPDOWN: Interface GigabitEthernet4/1, changed state to up
Oct  3 13:06:47.987: %LINEPROTO-5-UPDOWN: Line protocol on Interface SM1/0, changed state to down
Oct  3 13:06:47.987: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/0, changed state to down
Oct  3 13:06:47.987: %LINEPROTO-5-UPDOWN: Line protocol on Interface SM1/1, changed state to up
Oct  3 13:06:47.987: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/1, changed state to up
Oct  3 13:06:48.271: %ILPM_FAULT-5-ILPM_WARNING: Warning: Ethernet Switch Network Modules with PoE Support need to be reloaded to function properly.
Oct  3 13:06:49.407: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.1(3)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 10-Aug-11 08:58 by prod_rel_team
Oct  3 13:06:49.411: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
Oct  3 13:06:49.423: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
Oct  3 13:06:49.423: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
Oct  3 13:06:58.839: %DSPRM-5-UPDOWN: DSP 2 in slot 0, changed state to up
Oct  3 13:06:58.839: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
Oct  3 13:07:15.887: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
Oct  3 13:07:59.787: %SYS-5-CONFIG_I: Configured from console by console
Oct  3 13:08:00.055: %LINK-3-UPDOWN: Interface GigabitEthernet4/0, changed state to up
Oct  3 13:08:01.055: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/0, changed state to up
Oct  3 13:11:46.175: %ETHSW_SM-3-ILP_RECOVERY_COMPLETE: Time taken for recovery after reload = 300 seconds.
Oct  3 13:19:35.303: %SRE_SM-6-STATE_CHANGE: SM1/0 changing state from SERVICE_MODULE_STATE_WREG to SERVICE_MODULE_STATE_ERRQ
Oct  3 13:29:35.903: %SRE_SM-6-STATE_CHANGE: SM1/0 changing state from SERVICE_MODULE_STATE_ERRQ to SERVICE_MODULE_STATE_SHDN
Oct  3 13:36:54.175: %LINEPROTO-5-UPDOWN: Line protocol on Interface SM1/1, changed state to down
Oct  3 13:36:55.191: %LINEPROTO-5-UPDOWN: Line protocol on Interface SM1/1, changed state to up
Oct  3 13:39:35.903: %SRE_SM-6-STATE_CHANGE: SM1/0 changing state from SERVICE_MODULE_STATE_SHDN to SERVICE_MODULE_STATE_FAIL
Oct  3 15:16:32.175: %LINEPROTO-5-UPDOWN: Line protocol on Interface SM1/1, changed state to down
Oct  3 15:16:33.191: %LINEPROTO-5-UPDOWN: Line protocol on Interface SM1/1, changed state to up
paolo bevilacqua
Try a stable IOS, eg 15.0(1)M
