Cisco 3945 vs 3945E from VPN feature perspective
Calin C.
Level 5
Level 5
Hello everybody,
I have an issue understanding the difference between 3945 and 3945E from VPN support perspective.
If you check this link here:
http://www.cisco.com/en/US/products/ps10536/prod_series_comparison.html
You will see that the 3945E doesn't even have an ISM slot for a VPN ISM module and of course I could not find any ISM module for 3945E (I think this is obvious).
Nevertheless, the above mentioned page and
http://www.cisco.com/en/US/products/ps10749/index.html
say "Embedded hardware-accelerated VPN encryption for secure connectivity" for 3945E
What I should understand from here?
That the Cisco 3945E supports the same VPN features (including packet encryption / decryption in hardware) like a Cisco 3945 with VPN ISM card?
Any help will be appreciated (voted) !
Thank you!
Calin
Both versions are mentioned in the ISR G2 Performance Overview. Perhaps that helps:
https://supportforums.cisco.com/servlet/JiveServlet/download/3786419-138672/ISR_G2_Perfomance.pdf
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Above link no longer exists, do you have a replacement ?
