04-06-2023 08:00 AM
Hi guys,
cisco 4321 router rebooting continuously. So i did console login physically , it is showing like this icon ################################# . Nothing showing . So how i take logs before rase a TAC.
04-06-2023 10:17 PM
hi,
is your console setting correct? 9600-N-1-N
try using other terminal emulation app (i.e. tera trem) or use another laptop.
04-06-2023 10:57 PM - edited 04-06-2023 10:57 PM
Turn off the Router - Connect the Console cable
- Turn ON the Router - Post a complete boot logs here to identify the issue
04-12-2023 02:19 AM
Okay boss thank you. Will try
04-08-2023 06:57 PM
If the router is constantly rebooting, then console into the router (do not reboot the router). Enable console logging and collect the console logs for about 5 minutes. Post the console logs here.
04-12-2023 02:20 AM
Sure , will try
