Cisco 4331 flow export from vrf
Dear all,
I have a problem regarding netflow export from a Cisco 4331. I want to export netflow traffic to a specific destination. The problem is that the source should be the loopback interface on the router which is in a specific VRF:
Example:
flow exporter TEST
destination x.x.x.x
source Loopback1
transport udp 2055
template data timeout 1
flow monitor My-Flow-Test
exporter TEST
record netflow-original
interface Loopback1
ip vrf forwarding TEST_VRF
ip address Y.Y.Y.Y 255.255.255.255
end
It´s working when I´m using a Loopback Interface which is not in an VRF but when I use the "vrf forwarding" the source Interface IP is wrong:
sh flow exporter TEST
Flow Exporter TEST:
Description: User defined
Export protocol: NetFlow Version 9
Transport Configuration:
Destination IP address: X.X.X.X
Source IP address: "Not Y.Y.Y.Y"
Source Interface: Loopback1
Transport Protocol: UDP
Destination Port: 2055
Source Port: 53015
DSCP: 0x0
TTL: 255
Output Features: Used
Does anyone have an Idea how to resolve this problem? I need to export through this Loopback Interface over that VRF.
Best regards,
Kevin
Julio E. Moisa
If you are using VRF probably there is no communication between your loopback and the Netflow collector server because the loopback is under a VRF and the Netflow collector is over the global routing table, so you could verify it to enable routing between them, you could use static routes depending of your topology.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thanks for your reply. The routing between the loopback(In the TEST_VRF) and the destination server is working fine. I guess it´s a configuration issue because if we use the normal ip-flow commands we have the same issue on other Cisco routers.
We have to configure the VRF explicit to make it work:
#ip flow-export destination x.x.x.x 2055 vrf TEST_VRF
Otherwise if we use "#ip flow-export destination x.x.x.x 2055" in the "sh ip flow export" the given Loopback IP-Address is not right:
#sh ip flow export
Flow export v9 is enabled for main cache
Export source and destination details :
VRF ID : Default
Source(1) "Not the LoopbackIP" (Loopback1)
Destination(2) x.x.x.x (2055)
Version 9 flow records
But this configuration will not work on Cisco 4331.
perkin
Hello
I have the same question and after I googled it seems that is work as (cisco) design
you can refer to this discussion
https://community.cisco.com/t5/switching/netflow-vrf-export/td-p/1339418
even I tried on 16.9 code and that still the same..
so that is support on VRF but it (seems) it is not supported on the "real" mgmt interface / mgmt-intf
hope this help form a year later.
