Cisco 4461 ROMMON
TW80CJ5
Level 3
Level 3
Good Morning!
We are trying to get a ISR 4461 Router into ROMMON and are having a difficult time. We have tried Break, Pause/Break, Ctrl+C, and Esc.
Any ideas?
10 Replies 10
balaji.bandi
If  CTRL-C does not break the boot operation but by sending a BREAK (for example, from putty menu, Special Command --> Break) does work ?
still issue other option :
you eject the CF and then boot up the router go in to ROMMON.
BB
TW80CJ5
Level 3
Level 3
BB, thanks for the help as always. Sending the Break via Putty as a special command worked like a charm!
balaji.bandi
Cheers it worked, so we take this as resolved.
BB
TW80CJ5
Level 3
Level 3
Yes! Where is the accept solution..?
Also, I am unable to type any commands at rommon>
Thoughts?
TW80CJ5
Level 3
Level 3
I tried a diff console cable and it worked!!!!
balaji.bandi
Sorry you posted in wrong place, there is no solved here.
rommon > used to revovery or failed boot
not sure what is the puspose of you want to get in to ROMMON mode ?
BB
Leo Laohoo
Format the flash or use the following command to force the router into ROMMON:
factory-reset all
Loe,
The other question I posted about having a 4461 with SD Wan and not wanting to use the features....
It wont load, due to a page error, so I am gonna respond here.
Here is what I have tried
1. At the user exec when I try "factory-reset all" I get a "command not supported"
2. At the privlige exec, when I try "factory-reset all" I get a "syntax error: unknow command"
3. At Rommon, there is no "factory-reset all"
4. At Rommon, I tried the "reset" command and then boot, but it did not work.
Thoughs ????
Loe,
Thoughts ????
I have moved my response(s) to your other thread (LINK).
