Cisco 4500 CatOs, help initial config
Ranbeckycr_2
Hello Experts,
I have been reading for the last 3 days on how to setup this old switch 4500. It is running CATOS and I want to make
sure that when I connect it to the network it doesn't create a loop since it has to be compatible with other vendors, not just Cisco.
I don't have anything connected but these are my concerns:  It doesn't show my lacp-channel (i believe this is what is used to for Teaming network cards), it doesn't show my trunk ports.
TestSwitch> (enable) show lacp-channel
No ports channelling
TestSwitch> (enable) show trunk ?
  detail                     Show detailed information
  <mod>                      Module number
  <mod/port>                 Module number and Port number(s)
  extended-range             Show extended range entries
  |                          Output modifiers
  <cr>
TestSwitch> (enable) show trunk det
No ports trunking.
No ports trunking.
TestSwitch> (enable) sh config
This command shows non-default configurations only.
Use 'show config all' to show both default and non-default configurations.
begin
# ***** NON-DEFAULT CONFIGURATION *****
#time: Thu Oct 27 2011, 13:22:03
#version 8.4(9)GLX
#dot1x
set feature dot1x-radius-keepalive disable
#system
#Inlinepower
set inlinepower defaultallocation 6000
#frame distribution method
set port channel all distribution mac both
#default portcost mode
set spantree defaultcostmode long
#stp mode
set spantree mode mst
#vtp
set vtp domain Testing
set vtp mode off vlan
set vlan 40 name Mathew type ethernet mtu 1500 said 100040 state active
set vlan 50 name Mark type ethernet mtu 1500 said 100050 state active
set vlan 55 name Luke type ethernet mtu 1500 said 100055 state active
set vlan 80 name John type ethernet mtu 1500 said 100080 state active
set vlan 1002 name fddi-default type fddi mtu 1500 said 101002 state active
set vlan 1004 name fddinet-default type fddinet mtu 1500 said 101004 state active stp ieee
set vlan 1005 name trnet-default type trbrf mtu 1500 said 101005 state active stp ibm
set vlan 1
set vlan 1003 name token-ring-default type trcrf mtu 1500 said 101003 state active mode srb aremaxhop 7 stemaxhop 7 backupcrf off
#ip
set interface sc0 50 10.10.10.249/255.255.255.0 10.10.10.255
set interface sl0 down
set interface me1 10.20.0.1 255.255.255.0 10.20.0.255
set ip route 0.0.0.0/0.0.0.0         10.10.10.254
set ip alias default         0.0.0.0
#set boot command
set boot config-register 0x10f
set boot system flash bootflash:cat4000-k9.8-4-9-GLX.bin
#channelprotocol
set channelprotocol lacp 1
set channelprotocol lacp 2
set channelprotocol lacp 3
#port channel
set port lacp-channel 2/3-4 127
set port lacp-channel 3/3-4 129
set port lacp-channel 3/1-2 131
set port lacp-channel 2/1-2 132
#multicast filter
set igmp filter disable
#module 1 : 2-port 1000BaseX Supervisor
#module 2 : 48-port 10/100BaseTx Ethernet
set vlan 40   2/3-48
set vlan 50   2/1-2
set trunk 2/1  desirable dot1q 1-1005,1025-4094
set trunk 2/2  desirable dot1q 1-1005,1025-4094
#module 3 : 48-port 10/100/1000 Ethernet
set vlan 50   3/1-48
set trunk 3/1  desirable dot1q 1-1005,1025-4094
set trunk 3/2  desirable dot1q 1-1005,1025-4094
#module 4 empty
#module 5 empty
#module 6 empty
end
I belive these are logs from the switch you just configured.
I can see that you are using MST mode in spanning tree. However, I can't see any MST config other than
For MST to work you need to have a region name, revision number and instances of what vlans you want to group togther. I have pasted a sample  config. It's been a while since I worked on CatOS henc you need to just double check the commands.
CatOS
#MST Configuration
set spantree mst config rollback force
set spantree mst config name  revision 0
set spantree mst 0 vlan
IOS
switchB(config)# spanning-tree mst configuration
switchB(config-mst)# name corpbuilding
switchB(config-mst)# revision 1
switchB(config-mst)# instance 1 vlan 1 - 5
switchB(config-mst)# instance 2 vlan 6 - 10
Maybe this link might help you a bit
http://www.tek-tips.com/viewthread.cfm?qid=1627398
Kishore
5 Replies 5
Ranbeckycr_2
I connected this switch to the network and the network collapsed:
Got this error messages:
2011 Oct 27 15:40:23 %SPANTREE-2-MST_CHOP_MREC:Rcvd malformed MST bpdu on 3/15 (payload len 118)
2011 Oct 27 15:40:25 %SPANTREE-2-MST_CHOP_MREC:Rcvd malformed MST bpdu on 3/15 (payload len 118)
2011 Oct 27 15:40:27 %SPANTREE-2-MST_CHOP_MREC:Rcvd malformed MST bpdu on 3/15 (payload len 118)
2011 Oct 27 15:40:29 %SPANTREE-2-MST_CHOP_MREC:Rcvd malformed MST bpdu on 3/15 (payload len 118)
2011 Oct 27 15:40:31 %SPANTREE-2-MST_CHOP_MREC:Rcvd malformed MST bpdu on 3/15 (payload len 118)
----------> Port fast is disabled on each port that connects to another switch.
CatOS
#MST Configuration
IOS
Kishore
Kishore,
Thanks for your reply, I enabled MST because I thought that was required for a NonCisco equipment.
If you have any idea as to what configuration is needed to connect to a 3rd party Switch please let me know.
Oddly enough, even if I just plug 1 port to the network, my network will start having problems, dropping random connections.  Once computers start randomly dropping they never come back up until I disconnect the Switch.
Thanks!!
Right on the money!!!  Thanks Kishore, we had to add the mst group just as you suggested.  Will monitor but the network is not shutting down.
Hello Guys,
I have one 4506 chassis switch which stuck and not booting.  I am not getting anything on the screen by connecting with console.
PoE status light on each slot is red.
utilization lights on supervisor is randomly flashing in a loop.
I  already tried pressing reset button before powering on but it doesn't help.
Any suggestions
