L3 Etherchannel facing an L2 etherchannel
ernesttelecom1
Hello forum,
I found this setup and I was wondering if it is a valid setup to connect two routers via Etherchannel (LACP). One end as L3 with an IP address and the other side as L2 like the config below.
----------------------L3 Side (Cisco ASR1001)-----------------------
interface Port-channel2
ip address x.x.x.xx.x.x.x.x
no ip redirects
no ip unreachables
negotiation auto
interface GigabitEthernet0/0/2
no ip address
negotiation auto
channel-group 2 mode active
interface GigabitEthernet0/0/3
no ip address
negotiation auto
-----------------------L2 Side (Cisco ASR 920)-----------------------
interface Port-channel4
no ip address
negotiation auto
service instance 800 ethernet
encapsulation untagged
bridge-domain 800
interface GigabitEthernet0/0/4
no ip address
media-type rj45
negotiation auto
cdp enable
channel-group 4 mode active
interface GigabitEthernet0/0/5
no ip address
media-type rj45
negotiation auto
cdp enable
Issue I'm having is on the ASR920 side both interfaces are flaping in/out the etherchannel like the logs
Feb 05 17:19:30.406: GigabitEthernet0/0/4 taken out of port-channel4
Feb 05 17:19:31.267: GigabitEthernet0/0/4 added as member-2 to port-channel4
Feb 05 17:19:46.478: GigabitEthernet0/0/5 taken out of port-channel4
Feb 05 17:19:47.381: GigabitEthernet0/0/5 added as member-2 to port-channel4
Feb 05 17:20:51.949: GigabitEthernet0/0/4 taken out of port-channel4
Feb 05 17:20:52.840: GigabitEthernet0/0/4 added as member-2 to port-channel4
Feb 05 17:21:14.371: GigabitEthernet0/0/5 taken out of port-channel4
Feb 05 17:21:15.260: GigabitEthernet0/0/5 added as member-2 to port-channel4
Feb 05 17:22:14.560: GigabitEthernet0/0/4 taken out of port-channel4
Feb 05 17:22:14.806: GigabitEthernet0/0/4 added as member-2 to port-channel4
Feb 05 17:22:41.367: GigabitEthernet0/0/5 taken out of port-channel4
Feb 05 17:22:42.322: GigabitEthernet0/0/5 added as member-2 to port-channel4
Thanks for any help
Richard Burts
I believe that what you have here is not a valid implementation. When you are doing Etherchannel it can be treated as layer 2 or as layer 3. But both ends of the Etherchannel need to treat it the same way.
Rick
Rick
Richard Burts
Rick
Rick
