Cisco 4507R with Sup6-E QoS
ralphcarter
Hey Guys,
I'm trying to use a Sup6-E to do some intelligent shaping. I'm getting an error and I think its because of the architecture of the 4500 QoS. Most likely this type of QoS is not supported so I was wondering if anyone had any ideas on how to implement this QoS policy.
This is what I want to accomplish
class-map match-any PRIORITY-QUEUE
match dscp ef
match dscp cs5
match dscp cs4
class-map match-any CONTROL-MGMT-QUEUE
match dscp cs7
match dscp cs6
match dscp cs3
match dscp cs2
class-map match-any NETWORK-CRITICAL
match dscp cs6
match dscp cs2
class-map match-any MULTIMEDIA-CONFERENCING-QUEUE
match dscp af41 af42 af43
class-map match-any MULTIMEDIA-STREAMING-QUEUE
match dscp af31 af32 af33
class-map match-any TRANSACTIONAL-DATA-QUEUE
match dscp af21 af22 af23
class-map match-any BULK-DATA-QUEUE
match dscp af11 af12 af13
class-map match-any SCAVENGER-QUEUE
match dscp cs1
policy-map 1P7Q1T
class PRIORITY-QUEUE
  priority
class CONTROL-MGMT-QUEUE
  bandwidth remaining percent 10
class MULTIMEDIA-CONFERENCING-QUEUE
class MULTIMEDIA-STREAMING-QUEUE
class TRANSACTIONAL-DATA-QUEUE
  dbl
class BULK-DATA-QUEUE
  bandwidth remaining percent 4
  dbl
class SCAVENGER-QUEUE
class class-default
  bandwidth remaining percent 25
  dbl
ip access-list extended ACL-SITE1
permit ip any 172.16.1.0 0.0.0.255
ip access-list extended ACl-SITE2
permit ip any 172.17.1.0 0.0.0.255
class-map match-all CLASS-SITE1
match access-group name ACL-SITE1
class-map match-all CLASS-SITE2
match access-group name ACL-SITE2
When I create my Parent/Child Policy-map I get an error. Is there any way i can meet the objective which is, match the ACLs, shape their bandwidth to 10Mbps and within their shaped 10Mbps bandwidth, allocate specific bandwidth percentages for the traffic matching Dscp values?
policy-map POLICY-WAN-SHAPER
class NETWORK-CRITICAL
class CLASS-ACL1
  shape average 10000000
  service-policy 1P7Q1T
class CLASS-ACL2
I get the following error when I try to apply the nested service-policy.
%Queuing actions can be at only one of the policy-maps in a hierarchical policy-map. Configuration failed!
Then apply to Sup6-E interface.
class class-default
  shape average 100000000
  service-policy POLICY-WAN-SHAPER
interface ten1/1
service-policy output POLICY-WAN
I know this can be done on the ASR and obviously this is not an ASR router but I'm trying to get this scenario fullfilled. Is it possible?
CCIE 26175
www.techsnips.com
Jerry Ye
The C4500 is not a WAN router, hense, it will not support HQoS.
This is the same story in the C6K LAN line card. But the good part is, the C6K has SIP/SPA to support WAN connectivity and features.
HTH,
jerry
