Cisco 5020 L3 routing to gateway device
Jason White
Level 4
Level 4
I have a 5020 setup with inter-vlan and am able to ping devices across the vlans. I am also able to ping the outside 8.8.8.8 from the 5020. If I point an end device to use the 5020 for the gateway it can't ping past the 5020. There is a firewall connected to the 5020 in vlan 100. I have also connected a router up to the 5020 and if I make the end device gateway the 2821 I am able to get out through the firewall.
interface Vlan100
no shutdown
description InsideProd L3
ip address 172.16.1.2/24
sh ip route:
0.0.0.0/0, ubest/mbest: 1/0, pending
*via 172.16.1.1, [1/0], 00:44:12, static
172.16.1.0/24, ubest/mbest: 1/0, attached, pending
*via 172.16.1.2, Vlan100, [0/0], 03:40:06, direct
172.16.1.2/32, ubest/mbest: 1/0, attached, pending
*via 172.16.1.2, Vlan100, [0/0], 03:40:06, local
172.16.10.0/24, ubest/mbest: 1/0, attached, pending
*via 172.16.10.1, Vlan110, [0/0], 04:28:19, direct
172.16.10.1/32, ubest/mbest: 1/0, attached, pending
*via 172.16.10.1, Vlan110, [0/0], 04:28:19, local
172.16.20.0/24, ubest/mbest: 1/0, attached, pending
*via 172.16.20.1, Vlan120, [0/0], 04:28:19, direct
172.16.20.1/32, ubest/mbest: 1/0, attached, pending
*via 172.16.20.1, Vlan120, [0/0], 04:28:19, local
172.16.30.0/24, ubest/mbest: 1/0, attached, pending
*via 172.16.30.1, Vlan130, [0/0], 04:28:19, direct
172.16.30.1/32, ubest/mbest: 1/0, attached, pending
*via 172.16.30.1, Vlan130, [0/0], 04:28:19, local
172.16.40.0/24, ubest/mbest: 1/0, attached, pending
*via 172.16.40.1, Vlan140, [0/0], 04:28:22, direct
172.16.40.1/32, ubest/mbest: 1/0, attached, pending
*via 172.16.40.1, Vlan140, [0/0], 04:28:22, local
Static-route for VRF "default"(1)
IPv4 Unicast Static Routes:
0.0.0.0/0, configured nh: 172.16.1.1/32
(installed in urib)
rnh(installed in urib)
Static-route for VRF "management"(2)
(not installed in urib)
Jon Marshall
Is the end device in vlan 100 ?
If not then does the firewall have a route for the end device subnet pointing back to the switch ?
Jon
