NIM-2CE1T1-PRI - Mixed data and packet voice
Rafael Jimenez
Level 4
Level 4
I want purchase a ISR4000 with one NIM-2CE1T1-PRI to mix data and voice, both for E1.
The NIM-2CE1T1-PRI come with two ports, I want use only one for voice, my question is:
Which PVDM should I use, PVDM-32 or PVDM-64?. I believe that is PVDM-32 , but I need to make sure.
Thanks.
it depends on how many channels you need. PVDM4-32 has, obviously, 32 channels, PVDM4-256 has 256.
Check this link:
http://www.cisco.com/c/en/us/support/docs/routers/4000-series-integrated-services-routers/118792-config-isr-00.html#anc8
