Cisco 6500 - IPv6 Netflow configuration
Lee Kendrick
I need to deploy Netflow for IPv6 on my Cisco Cat6500, but i am unable to see the configuration commands.
From the config guides - this should be pretty straight  forward:
SUMMARY STEPS
1. enable
2. configure terminal
3. ipv6 flow-export version 9 [origin-as | peer-as] [bgp-nexthop]
4. ipv6 flow-export destination ip-address udp-port
5. ipv6 flow-export template {refresh-rate packet-refresh-rate | timeout timeout-value}
6. ipv6 flow-export template options {export-stats | refresh-rate packet-refresh-rate | timeout timeout-value}
7. interface type number
8. ipv6 flow {ingress | egress}
When i look for the commands they are not available:
router1(config)#ipv6 ?
  access-list        Configure access lists
  cef                Cisco Express Forwarding for IPv6
  dhcp               Configure IPv6 DHCP
  general-prefix     Configure a general IPv6 prefix
  hop-limit          Configure hop count limit
  host               Configure static hostnames
  icmp               Configure ICMP parameters
  local              Specify local options
  mfib               Multicast Forwarding
  mld                Global mld commands
  multicast          Configure multicast global commands
  multicast-routing  Enable IPv6 multicast
  nd                 ND
  neighbor           Neighbor
  ospf               OSPF
  pim                Configure Protocol Independent Multicast
  prefix-list        Build a prefix list
  route              Configure static routes
  router             Enable an IPV6 routing process
  source-route       Process packets with source routing header options
  tacacs             TACACS configuration commands
  unicast-routing    Enable unicast routing
router1(config)#
i am running these codes:
s72033-adventerprisek9_wan-mz.122-33.sxj5.bin
s72033-adventerprisek9_wan-mz.122-33.SXJ1.bin
when looking at the feature navigator - it shows 'Netflow for IPv6 Unicast traffic' as a valid feature..
Please point me in the right direction.
Many thanks
pedersen
You’ll need to use the MLS flow commands, since it running with the SUP720, like “mls flow ipv6 inteface-full”, the configuration is quite similar to your IPv4 netflow configuration.
mls flow ipv6 interface-full
mls nde sender
ip flow-export version 9
ip flow-export destination 172.16.10.2 2055
/Anders
