Cisco 7206VXR rate-limit not working
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-21-2013 02:55 AM - edited 03-04-2019 08:49 PM
I've Cisco 7206 VXR with IOS "c7200p-advipservicesk9_li-mz.124-15.T3.bin". We have MPLS connections terminated with the VLANS on the fiber gig port. I've applied rate-limit for inbound/outgoing traffic not to exceed certain limit.
But, still I'm seeing traffic is going more than the applied limit.
Ex: This 8MB rate limit applied on subinterface
rate-limit input 8384000 12800 12800 conform-action transmit exceed-action drop
Does anyone has any idea?
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-21-2013 04:49 AM
What's the output of 'show interface rate-limit'? Instead of CAR, shaping is used more often on CE. Any reason you prefer CAR over shaping?
HTH,
Lei Tian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-21-2013 05:27 AM
Thanks for the response. I want to restrict both inbound and outbound, thats the reason using the CAR.
The output is as below.
GigabitEthernet0/2.106 xxx Company 8Mbps
Input
matches: all traffic
params: 8384000 bps, 4192 limit, 4192 extended limit
conformed 3400147 packets, 344625643 bytes; action: transmit
exceeded 509285 packets, 301767312 bytes; action: drop
last packet: 4ms ago, current burst: 66 bytes
last cleared 01:32:43 ago, conformed 495000 bps, exceeded 433000 bps
Output
conformed 2338356 packets, 483254441 bytes; action: transmit
exceeded 257774 packets, 100000671 bytes; action: drop
last packet: 8ms ago, current burst: 1518 bytes
last cleared 01:31:34 ago, conformed 703000 bps, exceeded 145000 bps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-22-2013 03:24 AM
Looks like the CAR is dropping exceed packets, why do you think it is not working?
HTH,
Lei Tian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-22-2013 04:37 AM
Sometimes due to malware/virus activity there is lot of burst in the traffic which is recorded by the SNMP/MRTG monitors. Which is exceeding (going over 20MBPS) what is configured on the interface. Also the CPU usage was drastically increasing during the traffic floodings.
Ex: below see the exceeding value.
GigabitEthernet0/2.106 XXX Company 8Mbps
Input
conformed 31582020 packets, 4706M bytes; action: transmit
exceeded 15257155 packets, 10113M bytes; action: drop
last packet: 252ms ago, current burst: 0 bytes
last cleared 20:16:59 ago, conformed 515000 bps, exceeded 1108000 bps
Output
conformed 16301291 packets, 2979M bytes; action: transmit
exceeded 3877345 packets, 882109946 bytes; action: drop
last packet: 376ms ago, current burst: 0 bytes
last cleared 20:15:50 ago, conformed 326000 bps, exceeded 96000 bps
Is there any other way to stop this kind of flooding which is causing high cpu/mem and B/W utilization.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-23-2013 03:41 AM
CAR is doing its job. You might want talk to the provider see what service they can provide to block the abnormal traffic rate on their end. If no luck, you can consider platform that can do inbound policing in hardware and can do CoPP to protect CPU.
HTH,
Lei Tian
