Cisco 7206VXR throughput
fadi.hamamdeh
I want ask how max throughput for Cisco 7206VXR (NPE-G2)?
2 Accepted Solutions
the 2M pps Joseph mentioned equal 1024Mbps (check the attached sheet), so that would be about 1Gig.
Mpps is million packets per second.
". . . can load 2Gig throughput"
That depends on the nature of your traffic and your configuration. I.e. maybe, maybe not.
Georg provides the old Cisco router performance sheet. If you read the top, it tells the bandwidth is calculated for 64 byte sized packets (Ethernet minimum). (Also note, this sheet's bandwidth calculation doesn't take into account L2 overhead - i.e. it doesn't account for actual bandwidth on the wire.) Usually the device's bandwidth capacity goes up (a lot) as packet size increases. (Also note, usually device's PPS capacity decreases as packet size increases.) Also usually the bandwidth capacity goes down when you start "doing things" to the traffic (e.g. passing it through an ACL).
Also remember, the PPS and/or bandwidth may need to account for duplex traffic. For example, if you have a gig Ethernet interface, using full duplex, you would need to support 2 gig of bandwidth. (Also BTW, you need about 1.488 Mpps for a gig of Ethernet bandwidth, at minimum Ethernet/IP packet sizes.)
From personal experience, using that old Cisco router performance sheet , I've found you often want to "max size" a Cisco router at about 1/4 the bandwidth capacity listed when dealing with full duplex traffic. I.e. for a G2, it's good/safe for about four to six 100 FE ports (running full duplex).
Also keep in mind, with gig ports in an VXR chassis, you'll also begin to hit the chassis bandwidth limits too. I recall (?) the 3 (?) buses are gig PCI.
7 Replies 7
Joseph W. Doherty
2 Mpps.
what 2 MPPS?, I want ask if this router can load 2Gig throughput
thank you ... :)
this router used for ISP company, it's good can load 2Gig.
thank you.
The information provided by Joseph is probably a whole lot more valuable than anything you can get from an (outdated) router performance sheet. A lab environment with consistent stream of equal-sized packets is not what you have in a real environment. Compare it to the gas mileage they give you when you shop for a new car. You never ever get that out of your car.
