cisco 7301
leungcm
Dear Sir,
We config the vlan on 7301 router. however, it does not work. The config is following:
interface GigabitEthernet0/0
no ip address
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
media-type rj45
no negotiation auto
hold-queue 4096 in
hold-queue 4096 out
interface GigabitEthernet0/0.21
encapsulation dot1Q 21 native
ip address 192.168.0.1 255.255.255.0
following is the show inter log
--- log ---
GigabitEthernet0/0 is down, line protocol is down
Hardware is BCM1250 Internal MAC, address is 0019.0767.5c1b (bia 0019.0767.5c1
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 198/255, txload 1/255, rxload 1/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Auto-duplex, Auto Speed, media type is RJ45
output flow-control is XON, input flow-control is XON
Last input never, output never, output hang never
Last clearing of "show interface" counters 1w3d
Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/4096 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 0 multicast, 0 pause input
17 packets output, 4472 bytes, 0 underruns
4 output errors, 0 collisions, 4 interface resets
4 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/0.21 is down, line protocol is down
Hardware is BCM1250 Internal MAC, address is 0019.0767.5c1b (bia 0019.0767.5c1b)
Internet address is 192.168.0.1/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 21.
any idea? thanks
Best regards
CM Leung
royalblues
Level 10
Level 10
The Gigabit interface is seen to be in a down state.
Can you confirm whether a cable is connected to this port.
The vlan must have been created in a switch and the 7301 is actually configured for the SVI (router on a stick)
Narayan
