Cisco 7600 cannot get bgp keepalives
akgun.ozsoy
I am trying to establish a BGP session between a Cisco 7600 and Juniper MX960, but this always stucks in OpenConfirm state.
access-4#show ip bgp v v VRF1 neighbors 166.63.168.197
BGP neighbor is 166.63.168.197,  vrf VRF1,  remote AS 5555,  local AS 65533, external link
  BGP version 4, remote router ID 195.2.1.21
  BGP state = OpenConfirm
  Last read 00:02:27, last write 00:02:27, hold time is 180, keepalive interval is 60 seconds
  Message statistics:
    InQ depth is 0
    OutQ depth is 0
                         Sent       Rcvd
    Opens:                  4          4
    Notifications:          2          1
    Updates:                0          0
    Keepalives:             4          0
    Route Refresh:          0          0
    Total:                 10          5
  Default minimum time between advertisement runs is 30 seconds
debugging tcp packets
May 12 13:58:07.531 bst:     TCP src=54912, dst=179, seq=1766275951, ack=1681278050, win=17520 ACK PSH
May 12 13:58:07.535 bst: IP: tableid=2, s=166.63.168.198 (local), d=166.63.168.197 (Vlan20), routed via FIB
May 12 13:58:53.883 bst: IP: tableid=2, s=166.63.168.198 (local), d=166.63.168.197 (Vlan20), routed via FIB
May 12 13:58:59.359 bst: IP: s=166.63.168.197 (Vlan20), d=166.63.168.198, len 61, rcvd 2
May 12 13:58:59.359 bst:     TCP src=54912, dst=179, seq=1766276010, ack=1681278050, win=17520 ACK PSH FIN
May 12 13:58:59.359 bst: IP: tableid=2, s=166.63.168.198 (local), d=166.63.168.197 (Vlan20), routed via FIB
May 12 13:58:59.359 bst: %BGP-3-NOTIFICATION: received from neighbor 166.63.168.197 4/0 (hold time expired) 0 bytes
ICMP works fine.
It is same on JUniper end. Sending keepalives but cannot receive
###interface config
interface Vlan20
ip vrf forwarding VRF1
ip address 166.63.168.198 255.255.255.252
no ip redirects
no ip proxy-arp
load-interval 30
end
###bgp config
neighbor 166.63.168.197 remote-as 5555
neighbor 166.63.168.197 local-as 65533
neighbor 166.63.168.197 ebgp-multihop 5
neighbor 166.63.168.197 update-source Vlan20
neighbor 166.63.168.197 activate
neighbor 166.63.168.197 soft-reconfiguration inbound
hbruyere
Maybe a mtu issue causing updates to be dropped?
For a quick check disable bgp path mtu discovery so that the bgp mss falls back to 536 bytes:
router bgp x
no bgp transport path-mtu-discovery
Herve
ssheorai
Hi ,
I faced a similar issue. My ISP upgraded their Junos router OS and the bgp peering was not coming up. They did shut -unshut and session clearing but to no avail. But when we re-configured BGP on our Cisco 7609 for the VRF neighbor peering came up. So want to know what could be the reason for this.
Any help or suggestion welcome.
