Possible to Route Traffic Based on AVC?
Dan Man
Is it possible to route traffic, based on the Application Visibility Control functions that specific Cisco routers are capable of?  Here's my issue:  I have two ISP's.  One is at about 120% utilization.  The other isn't doing anything.  I can specify ip routes based on IP addresses.  For instance, I can ip route 173.252.110.27 255.255.255.255 10.x.x.x to point to our ISP2 firewall, which is our non-utilized provider, for Facebook traffic.  The problem is that sites like this have massive public subnets, so I won't be able to capture all of the traffic destined to Facebook.  Is there a way to route traffic based on application?  I know that Palo Alto firewalls have a way to do Policy Based Forwarding, based on application.  I was wondering if the same was possible with AVC.  Thanks for any help.
Hello.
Yes, it's possible and, actually, you have 2 ways.
1. use manual load-balanace between links.
2. use PfR to load-balance traffic automatically.
PS: you also will need NAT with route-map.
