Cisco 7600 competitive docs
burakdinci
I need a competitive documentation about Cisco 7600 vs. Juniper MX 960 , M320 series , Redback 1200 and Alcatel 7750. Any information will be helpful. Kind Regards...
Giuseppe Larosa
Hello Burak,
I think the best way to do this is to download the datasheet of all devices from the respective websites.
Then, you need to define a list of parameters and you use the datasheet to populate the table.
What parameters to consider depends from your application.
C7600 datasheet can be found here
http://www.cisco.com/en/US/products/hw/routers/ps368/products_data_sheets_list.html
Hope to help
Giuseppe
