ubr10k bgp convergence issue
echelon360
I'm wondering if anyone has encountered a similar issue and if there is a way to resolve this.
We are conducting tests around BGP link failure detection on the uBR10k/SIP-600/10GigE SPA where it is taking around 8-9 seconds to detect the fibres being pulled from the transceiver.
Is there an option to speed this up?
thanks!
Giuseppe Larosa
Hello Clive,
if supported on your devices I would try to use BFD (bidirectional forwarding detection).
see
http://www.cisco.com/en/US/docs/ios/12_2sr/12_2sra/feature/guide/srbgpbfd.html
you can check if your systems support it with
feature navigator
www.cisco.com/go/fn
Hope to help
Giuseppe
