Cisco 7609 - Enable Password Unable to Break.
Akhileshpk_2
Hi all,
Cisco 7609 Router, Enable password unable to reset.
Many times CTRL+BREAK Key combination while booting the router does not takes the console to ROMMON.
Router boots using the IOS image in the bootdisk0: (For entering into the ROMMON, removed both the external Flash disks also - no use)
2 or three time in a day it enters in to the ROMMON while pressing CTRL+BREAK.
Tried in the ROMMON (one Sup is removed) with confreg 0x2142 followed by reset/boot commands, the router is booting with the startup config.
Any work around will be appreciated.!!!
Thanks and Regards
Akhil
Akhileshpk_2
This issue is resolved by pressing the ESC key while booting, which will takes you to RP mode. (Removed one RP)
Router-sp>
Router-sp>enable
Router-sp# erase nvram
Router-sp#reload
The solution may help you in the future!!
Thanks and Regards
Akhil
Very impressive, Akhil..
What about Cisco HP Blade 3200 ?
KA
