Cisco 800 Series - No Ethernet on VLAN's
alativitys
Greetings.
I recently got my hands on a Cisco 800, quite old but reliable device, but there are a number of problems during configuration.
I have successfully configured internet on FE4 (WAN), ping to 8.8.8.8.8 is fine, internet through another LAN behind NAT and using gateway 10.1.1.1.1.
Started to raise L2 ports, started with FE0 LAN, created VLAN10 and DHPC pool for it, it caused some difficulties, but eventually everything worked and devices were able to get IP over DHPC in the range 80.50.10.0/24.
But... there is no internet on this network, after studying a number of guides and documentation I could not find my mistake, so I am asking for help from more experienced colleagues.
Thank you all in advance, attached config and IP ping results.
altnet#ping 8.8.8.8 source vlan 10
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 80.50.10.1
Success rate is 0 percent (0/5)
altnet#
altnet#ping 8.8.8.8 source fas
altnet#ping 8.8.8.8 source fastEthernet 4
Packet sent with a source address of 10.1.3.57
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/56/56 ms
altnet#
Config:
altnet#show config
Using 1847 out of 262136 bytes
! Last configuration change at 03:44:44 UTC Wed Jan 17 2024
version 15.1
no service pad
hostname altnet
boot-start-marker
boot-end-marker
enable secret 5 SECRET
enable password SECRET
no aaa new-model
memory-size iomem 10
ip source-route
no ip routing
ip dhcp excluded-address 192.168.10.2
ip dhcp excluded-address 192.168.10.3
ip dhcp excluded-address 192.168.10.4
ip dhcp excluded-address 192.168.10.5
ip dhcp excluded-address 192.168.10.6
ip dhcp excluded-address 192.168.10.7
ip dhcp excluded-address 192.168.10.8
ip dhcp excluded-address 192.168.10.9
ip dhcp excluded-address 192.168.10.10
ip dhcp excluded-address 80.50.10.2 80.50.10.10
ip dhcp pool LAN_FE0
network 80.50.10.0 255.255.255.0
default-router 80.50.10.1
dns-server 1.1.1.1 8.8.8.8
no ip cef
ip name-server 1.1.1.1
ip name-server 8.8.8.8
no ipv6 cef
license udi pid CISCO881-K9 sn FCZ1521C2H2
interface FastEthernet0
switchport access vlan 10
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 10.1.3.57 255.0.0.0
ip nat outside
ip virtual-reassembly
no ip route-cache
duplex half
speed auto
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan10
ip address 80.50.10.1 255.255.255.0
ip nat inside
ip default-gateway 10.1.1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0 overload
ip route 0.0.0.0 0.0.0.0 10.1.1.1
ip route 80.50.10.0 255.255.255.0 10.1.1.1
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password SECRET
login
transport input all
end
altnet#
make the changes marked in bold:
altnet#show config
version 15.1
no service pad
hostname altnet
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
--> ip routing
no ip cef
no ipv6 cef
ip nat outside
no ip route-cache
duplex half
speed auto
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan10
ip nat inside
--> no ip default-gateway 10.1.1.1
no ip http server
--> no ip route 80.50.10.0 255.255.255.0 10.1.1.1
--> access-list 1 permit 80.50.10.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password SECRET
login
transport input all
end
alativitys
I made these changes and NAT debugging started working, attached:
altnet#conf t
Enter configuration commands, one per line. End with CNTL/Z.
altnet(config)#ip routing
altnet(config)#no ip default-gateway 10.1.1.1
altnet(config)#no ip route 80.50.10.0 255.255.255.0 10.1.1.1
altnet(config)#access-list 1 permit 80.50.10.0 0.0.0.255
altnet(config)#end
altnet#
*Jan 17 08:55:33.371: %SYS-5-CONFIG_I: Configured from console by console
altnet#write memory
Building configuration...
[OK]
altnet#ping 1.1.1.1
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 36/38/40 ms
altnet#ping 1.1.1.1 so
altnet#ping 1.1.1.1 source vlan 10
altnet#
*Jan 17 08:56:25.415: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:56:25.419: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:56:25.639: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:56:26.143: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:56:26.639: NAT: translation failed (A), dropping packet s=80.50.10.11 d=8.8.8.8
*Jan 17 08:56:27.639: NAT: translation failed (A), dropping packet s=80.50.10.11 d=8.8.8.8
*Jan 17 08:56:29.643: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:56:29.643: NAT: translation failed (A), dropping packet s=80.50.10.11 d=8.8.8.8
*Jan 17 08:56:30.407: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:56:33.643: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:56:33.643: NAT: translation failed (A), dropping packet s=80.50.10.11 d=8.8.8.8
*Jan 17 08:56:35.867: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:56:37.655: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:56:37.655: NAT: translation failed (A), dropping packet s=80.50.10.11 d=192.168.104.34
*Jan 17 08:56:38.659: NAT: translation failed (A), dropping packet s=80.50.10.11 d=192.168.104.34
*Jan 17 08:56:38.663: NAT: translation failed (A), dropping packet s=80.50.10.11 d=8.8.8.8
*Jan 17 08:56:39.663: NAT: translation failed (A), dropping packet s=80.50.10.11 d=8.8.8.8
*Jan 17 08:56:40.675: NAT: translation failed (A), dropping packet s=80.50.10.11 d=192.168.104.34
*Jan 17 08:56:41.679: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:56:41.679: NAT: translation failed (A), dropping packet s=80.50.10.11 d=8.8.8.8
*Jan 17 08:56:44.687: NAT: translation failed (A), dropping packet s=80.50.10.11 d=192.168.104.34
*Jan 17 08:56:45.679: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:56:45.679: NAT: translation failed (A), dropping packet s=80.50.10.11 d=8.8.8.8
*Jan 17 08:56:47.667: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:56:48.679: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:56:50.687: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:56:52.695: NAT: translation failed (A), dropping packet s=80.50.10.11 d=192.168.104.34
*Jan 17 08:56:54.699: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
altnet#
altnet#
*Jan 17 08:56:57.675: NAT: translation failed (A), dropping packet s=80.50.10.11 d=8.8.8.8
*Jan 17 08:56:58.679: NAT: translation failed (A), dropping packet s=80.50.10.11 d=8.8.8.8
*Jan 17 08:57:00.687: NAT: translation failed (A), dropping packet s=80.50.10.11 d=8.8.8.8
*Jan 17 08:57:02.147: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:57:02.703: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:57:04.699: NAT: translation failed (A), dropping packet s=80.50.10.11 d=8.8.8.8
*Jan 17 08:57:12.707: NAT: translation failed (A), dropping packet s=80.50.10.11 d=8.8.8.8
*Jan 17 08:57:25.191: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:57:25.951: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:57:26.859: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:57:26.947: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:57:28.283: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:57:30.879: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
*Jan 17 08:57:41.107: NAT: translation failed (A), dropping packet s=80.50.10.11 d=1.1.1.1
Hello @alativitys ,
your FAS0 is a L2 interface and NAT is clearly L3.
so I would suggest the following:
conf t
no ip nat inside source list 1 interface FastEthernet0 overload
ip nat inside source list 1 interface Fast4 overload
Hope to help
Giuseppe
alativitys
I'm still waiting for help with this issue
