Tunnel status up but protocol down
ss571
Here is my topology in gns3:
Screenshot 2024-01-19 010930.png I plan to form a tunnel between R3 and R4, and the loopback and tunnel interface is as shown next to the routers. I've set the tunnel source and destination for both routers with the loopback interfaces, and all physical and loopback interfaces are up for R1-4. The MTU value for both routers is the same too. But when I checked the "sh ip int br" for R3 and R4, the tunnel interface status is up, but protocol is down. May I know why is this occurring?
Below are the sh ip int br for R3 and R4:
As I guess
never use same IGP for both tunnel and it is tunnel source
here you use OSPF 1 for tunnel and for tunnel source (looback which is no correct add to OSPF)
so what you need is
A-interface loopback
ip ospf network point-to-point
<<- you need to add this in both router
B-router ospf 1  <<- you need to add this in both router
net <LO IP> area 0
C-router ospf 10 <<- you need to add this in both router
net <tunnel IP> area 0
why need two separate OSPF ?
https://study-ccnp.com/gre-tunnels-recursive-routing-problems/
MHM
17 Replies 17
you need to be sure that the LO is reachable otherwise the tunnel is DOWN
MHM
LO meaning the loopback int? I apologize for my lack of knowledge as I'm new to this field
Yes correct LO is loopback
show route in both routers
check if you see LO of other router
MHM
No i don't see the LO for R4 in show route in R4
Hello @ss571
Add static route on R3 R1 R2 and R4 in order to route Loopback interfaces. You should be able to ping Loopack on each routers R3 and R4.
@MHM Cisco World give you the rigth answer.
Best regards
ss571
Also is it a need to add in the static routes in R3 and R4 for the tunnel to work?
you need static route only for LO to make reachable
when it reachable the Tunnel will be UP/UP and appear in both routers as connect
MHM
ss571
Btw In R1 and R2 there is ospf configured as well, do i add the networks in the ospf or add in the addresses as the neighbours?
can I see the config of R1 and R2
thanks
MHM
ss571
Yeah sure, here they are:
R1
upgrade fpd auto
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
redundancy
ip tcp synwait-time 5
interface Port-channel1
 ip address 148.90.255.33 255.255.255.252
 ip ospf authentication message-digest
 ip ospf message-digest-key 1 md5 key
 hold-queue 150 in
interface FastEthernet0/0
 ip address 148.90.255.37 255.255.255.252
 duplex half
interface GigabitEthernet1/0
 ip address 148.90.255.14 255.255.255.252
 ip ospf cost 10
 negotiation auto
interface GigabitEthernet2/0
 ip address 148.90.255.2 255.255.255.252
 negotiation auto
interface GigabitEthernet3/0
 ip address 148.90.255.17 255.255.255.252
 negotiation auto
interface GigabitEthernet4/0
 ip address 148.90.255.25 255.255.255.252
 ip ospf cost 10
 negotiation auto
interface GigabitEthernet5/0
 no ip address
 negotiation auto
 channel-group 1
interface GigabitEthernet6/0
 no ip address
 negotiation auto
 channel-group 1
router ospf 1
 network 148.90.252.0 0.0.0.255 area 20
 network 148.90.253.0 0.0.0.255 area 20
 network 148.90.254.0 0.0.0.255 area 20
 network 148.90.255.0 0.0.0.3 area 0
 network 148.90.255.12 0.0.0.3 area 0
 network 148.90.255.16 0.0.0.3 area 0
 network 148.90.255.24 0.0.0.3 area 0
 network 148.90.255.32 0.0.0.3 area 0
 network 148.90.255.36 0.0.0.3 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
mgcp profile default
gatekeeper
 shutdown
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
 transport input all
end
Here is R2:
upgrade fpd auto
version 15.2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
ipv6 unicast-routing
ipv6 cef
redundancy
 ip address 148.90.255.34 255.255.255.252
 ip ospf cost 10
 ipv6 address 2001:148:90:2::16/127
 ipv6 ospf 1 area 0
 hold-queue 150 in
 ip address 148.90.255.41 255.255.255.252
 duplex half
 ip address 148.90.255.10 255.255.255.252
 ip ospf cost 10
 negotiation auto
 ipv6 address 2001:148:90:2::5/127
 ipv6 ospf 1 area 0
 ip address 148.90.255.6 255.255.255.252
 ip ospf cost 1
 negotiation auto
 ipv6 address 2001:148:90:2::3/127
 ipv6 ospf 1 area 0
 ip address 148.90.255.21 255.255.255.252
 ip ospf cost 1
 negotiation auto
 ipv6 address 2001:148:90:2::13/127
 ipv6 ospf 1 area 0
 ip address 148.90.255.29 255.255.255.252
 ip ospf cost 10
 negotiation auto
 ipv6 address 2001:148:90:2::11/127
 ipv6 ospf 1 area 0
 no ip address
 negotiation auto
 channel-group 1
 no ip address
 negotiation auto
 channel-group 1
router ospf 1
 area 0 authentication
 network 148.90.255.4 0.0.0.3 area 0
 network 148.90.255.8 0.0.0.3 area 0
 network 148.90.255.20 0.0.0.3 area 0
 network 148.90.255.28 0.0.0.3 area 0
 network 148.90.255.40 0.0.0.3 area 0
no ip http server
ipv6 router ospf 1
control-plane
gatekeeper
 shutdown
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
 transport input all
end
Btw now R3 tunnel protocol is up, but R4 protocol is still down
I need to see also R3 and R4 config
thanks
MHM
ss571
Alright, here is R3:
upgrade fpd auto
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
redundancy
interface Loopback0
 ip address 148.90.255.253 255.255.255.252
interface Tunnel0
 no ip address
interface Tunnel1
 ip address 192.168.0.1 255.255.255.252
 ip mtu 1400
 tunnel source 148.90.255.253
 tunnel destination 148.90.255.254
 ip address 148.90.255.38 255.255.255.252
 duplex half
 ip address 148.91.0.1 255.255.255.252
 negotiation auto
 no ip address
 shutdown
 negotiation auto
 no ip address
 shutdown
 negotiation auto
 no ip address
 shutdown
 negotiation auto
 no ip address
 shutdown
 negotiation auto
 no ip address
 shutdown
 negotiation auto
router ospf 1
 network 148.90.255.252 0.0.0.3 area 0
 network 192.168.0.0 0.0.0.3 area 0
 default-information originate
no ip http server
control-plane
gatekeeper
 shutdown
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
 transport input all
end
