Cisco 800 series router problems
vgurbanov
Hello.The internet speed of the Cisco 800 series router does not exceed 20 mb. How can we solve this problem?
Leo Laohoo
  1. Get a bigger router, preferably one that can handle >20 Mbps.
  2. Downgrade your WAN speed to match the router's capabilities.
9 Replies 9
Leo Laohoo
Is there no other way? this is the last option.
johnlloyd_13
Level 9
Level 9
hi,
as leo mentioned, it's already a limitation on the router/HW you're currently using.
just to cover basics, do you see any errors or output drops on the WAN interface? are you using any VPN?
post a 'show interface <WAN port>' output.
Hello. No vpn. Only internet. The internet image shows 100mb on another router but 20mb on this router. The reason for this is interesting to me.
20MB sounds extremely low...
Post the running configuration of your router, maybe we can spot something...
Thanks friends. I solved the problem.
ip route-cache cef
20MB would have been way too low even for that router. Glad you got it resolved. You might as well post your config anyway, maybe we can spot something else...
Building configuration...
Current configuration : 1813 bytes
version 15.2
no service pad
service password-encryption
boot-start-marker
boot system flash c880data-universalk9-mz.159-3.M1
boot-end-marker
shell processing full
no aaa new-model
memory-size iomem 10
ip cef
no ipv6 cef
license udi pid CISCO881-K9 sn FCZ174292ZG
interface FastEthernet0
no ip address
spanning-tree portfast
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
duplex full
interface FastEthernet4
ip address 10.172.6.253 255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex full
speed 100
interface Vlan1
bandwidth 10000000
ip address 172.16.16.16 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source list NAT interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 10.172.6.254
ip access-list extended NAT
permit ip host 172.16.16.0 any
access-list 1 permit 172.16.16.0 0.0.0.255
line con 0
no modem enable
line aux 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
end
you might want to take out this line (since it is redundant and not needed):
Other than that, the config looks by the book.
