Cisco 803 IOS or mss command on it.
muneer_bom3
Hi All,
on cisco 803 router (VPN CONNECTIVITY) i am not able to access remote locations Exchange server apart from this other application like SAP, FTP, etc working fine only OWA is not working.
checked and found that we have to configure mss to 1430 but this command is not there on ciso 803, I have to upgrade the ISO of the same, which i am not able to found on any site.
please post the link or is there anyway to configure the mss in cisco 803.
Thanx in advance
Muneer
6 Replies 6
spremkumar
Level 9
Level 9
Can you revert what kinda VPN you have deployed over there between ur locations ?
also are you trying out this command ip tcp adjust-mss to tweak the mss ?
Also can you paste the show version o/p of your router over here..
regds
thanx for replying
Wireless VPN from sify. from my head office to branch office.
yes i am trying adjust-mss on cisco 803 router which is not there, mtu also tried but dint get any any success.
IOS (tm) C800 Software (C800-Y6-MW), Version 12.1(7), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Thu 22-Feb-01 11:47 by kellythw
Image text-base: 0x000EA000, data-base: 0x00617000
ROM: TinyROM version 1.4(1)
Glenmark_Sanpada uptime is 5 days, 1 hour, 37 minutes
System image file is "flash:c800-y6-mw.121-71"
Cisco C803 (MPC850) processor (revision 1) with 43364K bytes of virtual memory
Processor board ID JAD06020CJS
CPU part number 0x2101
Bridging software.
Basic Rate ISDN software, Version 1.1.
2 POTS Ports
1 Ethernet/IEEE 802.3 interface(s)
1 ISDN Basic Rate interface(s)
4M bytes of physical memory (DRAM)
8K bytes of non-volatile configuration memory
8M bytes of flash on board (4M from flash card)
Best Regards
Muneer Ahmed
hi
As per the data sheets available this feature was introduced in 12.2(4)T ,command migration from ip adjust-mss to ip tcp adjust-mss happened in 12.2(8)T.
upgrade the ios code to 12.2 GD version to have the command configured under ur interface...
regds
Thnak YOu
please can me post the link of the same. pleease
Pleeeeeeassseee
Muneer
you need a CCO account to download IOS software from
http://www.cisco.com/public/sw-center/products.shtml
Providing you an IOS without you being entitled to get it would be a copyright violation.
Hope this helps
Martin
heres the link which talks about the tcp-adjust command support ..
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a00804247fc.html
You can very well download the reqd ios code from the link mentioned by Martin..
regds
