Cisco 804 Router - help
zoo-loo79
I purchased a used 804 router and it appears it has not been reset to the default config and I do not have the credentials to login to the router. In my terminal session, when I connect, I am prompted for my login credentials and I can not get to a prompt to enter commands. Where do I go from here to get this reset? The only factory default setting restore procedures that I have seen require that I have to enter commands, but I can not get to a prompt to do that? I am stuck. Thanks.
gpulos
Level 8
Level 8
use password recovery procedures to get the router to a prompt you can use.
see the following link for more info:
http://www.cisco.com/en/US/products/hw/routers/ps380/products_password_recovery09186a00800942c2.shtml
Thank you. I was able to follow those steps. However, what username do I use to login to the router once I have enabled the secret password? Thanks.
