Cisco 805 bridging config help?
Andrewhillard
Hopefully someone can shed some light on this problem.
Have two cisco 805 routers connected by a BT kilostream line.(64k)
Both routers have been configured for bridging, and connected together for test purposes with a DTE/DCE back to back test cable, with pcs either side of each router and both pcs can ping each other.
When the routers are put into the BT circuit, they both have a carrier detect light on the front, both ethernet and serial ports and protocols on both routers are up but machines either side of the routers can not ping each other, also no connection....
Any ideas?
Cheers in advance
8 Replies 8
chris.aguilar
Hi Andrew,
Can you post the router config to have a better view of the setup? It will help also if you can post a 'show int s0' here to see the status of the serial interfaces.
By the way, is it your requirement to do bridging between the 2 locations?
Cheers,
Chris
Here is config. Yes is requirement as they only have two users on link other end which is only used a couple of times a week.
Many Thanks
Current configuration : 522 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname main
boot system flash
ip subnet-zero
no ip routing
interface Ethernet0
no ip address
no ip route-cache
no ip mroute-cache
bridge-group 1
interface Serial0
bandwidth 64
no ip address
no ip route-cache
no ip mroute-cache
bridge-group 1
ip classless
ip http server
ip pim bidir-enable
bridge 1 protocol ieee
line con 0
stopbits 1
line vty 0 4
login
end
main#sh int
Ethernet0 is up, line protocol is up
Hardware is PQUICC Ethernet, address is 000b.fdf1.fc41 (bia 000b.fdf1.fc41)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Half-duplex, 10Mb/s
Last input never, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
77060 packets output, 5189970 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
Serial0 is up, line protocol is up
Hardware is PowerQUICC Serial
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/2/128 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
16230 packets input, 1086228 bytes, 0 no buffer
Received 14220 broadcasts, 0 runts, 0 giants, 0 throttles
4 input errors, 0 CRC, 4 frame, 0 overrun, 0 ignored, 0 abort
75060 packets output, 3303165 bytes, 0 underruns
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
main#
Hi Andrew,
From the looks of the config and the 'show int', everything is ok, unless, the remote router has some missing config, such as the 'bridge 1 protocol ieee' or maybe missing 'bridge group 1' on the interfaces.
Would you consider changing the config from bridging to routing so that you will have a granular way of troubleshooting the link?
Cheers,
Chris
Remote router has exactly the same settings other than hostname being different.
Thought about doing the routing way for better diagnostics, and did infact set them up for routing however I could not ping the remote routers. Only ping the local router.
Im convinced the link is at fauly but BT are sure that it is working.
Routers as i say have been linked together in bridge mode and other than adding a manual clock rate to one router on the dce end the config was left the same as above and a pc was put either side of the router. It all worked fine.
Any ideas would be great.
Many Thanks
Hi Andrew,
You've done back-to-back testing on the routers, you've changed it to routing mode and can't ping the remote router serial IP address, it's definitely the BT link that is not working. You can ask them to do a remote loopback on their CSU/DSU, and check if you can see the loopback from your main router. If you can't see the loopback, then there's your proof.
One more thing, what type of router/serial interface are you using? If in case you're using a router with sync/async (A/S) interface, it won't work for a leased line that is faster than 128Kpbs.
cheers,
Chris
Thanks very much for such quick responses from everyone, much appreciated.
Im using a smart serial cable from the back of the router X21 to the BT NTU(CSU/DSU) equipment.
64k leased line.
How do i go about seeing the loopback if I get BT to set on their equipment.
Am i pinging an address or something? or pinging my local router from within the IOS software?
Sorry for sounding dumb on this!
Hi Andrew,
If you ask BT to do a remote loopback on their CSU/DSU, you should see a "Serial0/0 is up, line protocol is up (looped)" from your main router serial interface.
This way, BT can prove to you that their leased circuit is working. If you don't see this, they might have a problem with the circuit.
cheers,
Chris
Ok
Many Thanks for al your help
Am having a joint meeting with BT engineers on monday, they are going to carry out an end to end test using bt equipment. BT engineer each end of the link with testers.
Lets see how it goes!
Thanks again
