Router to Router Connection
Live2 Bicycle
Level 3
Level 3
I am trying to test the conenction between 2 router before I ship one out to a remote location. The connection will be a Ds1 circuit. Just a cold piece of copper. One router is an 1841 with a WIC-1DSU-T1-V2 the other router is a 1602 with a WIC-1DSU-T1 wic.
I have tried a Cat 5 cross over and a straight through cable. Niether seem to work. When I use the cross over cable I get %QUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem? errors.
Here is the Config from the 1841
interface Serial0/1/0
description Connected to Library Park Office
ip address 10.0.0.9 255.255.255.248
service-module t1 clock source internal
service-module t1 timeslots 1-24
service-module t1 remote-alarm-enable
Here is the config from the 1602
interface Serial1
description Connected to Countyline office
ip address 10.0.0.10 255.255.255.248
Can I not connect routers driectly together in this manner or is there something wrong with my config?
dgahm
Level 8
Level 8
A T1 uses pairs 1,2 and 4,5. The ethernet is 1,2 and 3,6 which is why that did not work. A crossover cable wired for T1 will get you going.
1 - 4
2 - 5
4 - 1
5 - 2
dgahm
Level 8
Level 8
1 - 4
2 - 5
4 - 1
5 - 2
Thankyou! I did not realize there was different types of crossover cables. Onceyou pointed out there was a T1 crossover I goggled it and found this
http://www.netopia.com/en-us/support/technotes/hardware/NIR_035.html?print=yes
Thanks againg
