cisco 819-4g dual sim configuration
gevorgmo1
Hi, I have a cisco 819-4g, I  config with single sim, but, when I insert a second sim, and tray to create profile 2 for cellular 0 it say
Profile 2 NOT written to modem
and, I cant find this command
router(config-controller)# lte sim primary slot 0
router(config-controller)# lte sim profile 2 slot 0
in my router isn't this, ther is only
router(config-controller)# lte sim authenticate
Router#sh version
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.2(4)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 20-Jun-13 16:14 by prod_rel_team
ROM: System Bootstrap, Version 15.2(2r)T, RELEASE SOFTWARE (fc1)
Router uptime is 1 hour, 4 minutes
System image file is "flash:c800-universalk9-mz.SPA.152-4.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
Cisco C819G-4G-G-K9 (revision 6.0) with 883788K/33715K bytes of memory.
Processor board ID FCZ1747C2K3
4 FastEthernet interfaces
1 Gigabit Ethernet interface
1 Serial(sync/async) interface
2 terminal lines
1 Virtual Private Network (VPN) Module
1 Cellular interface
1 cisco Embedded AP (s)
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
1000944K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C819G-4G-G-K9         FCZ1747C2K3
License Information for 'c800'
    License Level: advipservices   Type: Permanent
    Next reboot license Level: advipservices
Please help me understand what I do wrong.
Thanks.
gevorgmo1
Can somebody help me on this official forum?
Anthony Cook
Any news on this? I have the same issue. Please see my output:
Router(config-controller)#lte sim ?
  authenticate  CHV1 authentication
The show version output is as follows:
Router#show version
Router uptime is 4 hours, 47 minutes
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Processor board ID FCZ1815C4U7
2 terminal lines
999936K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C819G-4G-G-K9         FCZxxxxxx
Anthony
