FVRF - cannot SSH into the router
remi-reszka
Does anybody know why after configuring a router for FVRF and IVRF I can no longer SSH into the box? As soon as the outside interface is placed in the FVRF I loose the remote connection and when try to reconnect the router refuses the SSH connection, what am I missing?
Thanks and best regards.
Remi
Hello.
Not clear what is your issue, but default behavior for ISR G1/G2 is to remove IP-address from the interface whenever you move it between VRFs.
To move interface between VRFs you either need second management interface or EMM script.
