Cisco 819 LTE Router
jdnelson711
I am having issues trying to create a cellular data profile, it is not the command that is the problem, but i choose to overwrite a profile it says "profile # NOT written to modem"
I did a debug on the cellular interface when adding a profile, and i get a message that say Profile_Set (Block).  When I do it on a device that i know it is working i get Profile_Summary (Unblock).  I have upgraded IOS, reloaded fifteen times, try fifty different things but no luck.  If anyone has seen this issue, or may can help that would be greatly appreciated.
Daniel
paolo bevilacqua
You can try the following
Edit configuration files with text editor. Copy to startup-config. Reload.
