07-31-2022 08:59 AM
I have cisco 819g-4g when i install sim 4g and config the apn it didnt connect to the service provider
If i take the same sim and config on asr1000 with the same configuration its works
What can be the problem?
The 819g come with modem sierra mc77100
07-31-2022 09:25 AM
can we see the config?
07-31-2022 09:28 PM
show ver
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.3(3)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 22-Oct-13 05:46 by prod_rel_team
ROM: System Bootstrap, Version 15.2(2r)T, RELEASE SOFTWARE (fc1)
Router uptime is 56 minutes
System image file is "flash:c800-universalk9-mz.SPA.153-3.M1.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C819G-4G-G-K9 (revision 6.0) with 883788K/33715K bytes of memory.
Processor board ID FCZ172594AG
4 FastEthernet interfaces
1 Gigabit Ethernet interface
1 Serial(sync/async) interface
2 terminal lines
1 Virtual Private Network (VPN) Module
1 Cellular interface
1 cisco Embedded AP (s)
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
999936K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 C819G-4G-G-K9 FCZ172594AG
License Information for 'c800'
License Level: advipservices Type: Permanent
Next reboot license Level: advipservices
Router# show run
Building configuration...
WLAN_AP_SM: Config command is not supported
Current configuration : 2126 bytes
! Last configuration change at 02:19:49 UTC Mon Aug 1 2022
version 15.3
no service password-recovery
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL1" TIMEOUT 20 "OK"
license udi pid C819G-4G-G-K9 sn FCZ172594AG
vtp mode transparent
controller Cellular 0
vlan 20
name xxx
vlan 1000
name xxx
interface Cellular0
ip address negotiated
no ip unreachables
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer string lte
dialer watch-group 1
dialer-group 1
async mode interactive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
ip address 192.168.1.254 255.255.255.0
ip nat inside
no autostate
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
dialer watch-list 1 ip 192.168.1.254 0.0.0.255
dialer watch-list 1 delay route-check initial 60
dialer watch-list 1 delay connect 1
dialer-list 1 protocol ip permit
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line 3
script dialer lte
modem always-on
no exec
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
07-31-2022 10:11 AM
turn om debugging and post the output:
debug modem
debug dialer
debug cellular 0 messages call control
07-31-2022 09:46 PM
*Aug 1 02:36:04.283: CHAT3: Chat script lte started
Router#show deb
Router#show debugging
General OS:
Modem control/process activation debugging is on
Dial on demand:
Dial on demand events debugging is on
CELLULAR:
CALLCONTROL debugging is on
Router#
*Aug 1 02:36:16.015: TTY0: pause timer type 1 (OK)
*Aug 1 02:36:16.015: TTY0: resume timer type 1 (OK)ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
*Aug 1 02:36:24.155: TTY0: pause timer type 1 (OK)
*Aug 1 02:36:24.283: CHAT3: Chat script lte finished, status = Connection timed out; remote host not responding
*Aug 1 02:36:24.283: TTY3: Line reset by "Async dialer"
*Aug 1 02:36:24.283: Ce0 DDR: disconnecting call
*Aug 1 02:36:24.283: TTY3: Modem: (unknown)->HANGUP
*Aug 1 02:36:24.283: TTY3: no timer type 0 to destroy
*Aug 1 02:36:24.283: TTY3: no timer type 1 to destroy
*Aug 1 02:36:24.283: TTY3: no timer type 3 to destroy
*Aug 1 02:36:24.283: TTY3: no timer type 4 to destroy
*Aug 1 02:36:24.283: TTY3: no timer type 10 to destroy
*Aug 1 02:36:24.283: TTY3: no timer type 2 to destroy.
*Aug 1 02:36:24.819: TTY3: dropping DTR, hanging up
*Aug 1 02:36:24.819: tty3: Modem: HANGUP->IDLE..
*Aug 1 02:36:29.819: TTY3: restoring DTR
*Aug 1 02:36:30.819: TTY3: Always-on modem
*Aug 1 02:36:30.819: tty3: Modem: IDLE->READY..
Success rate is 0 percent (0/5)
Router#show in
*Aug 1 02:36:34.155: TTY0: resume timer type 1 (OK)t vl 1
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is 20bb.c041.85e0 (bia 20bb.c041.85e0)
Internet address is 192.168.1.254/24
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive not supported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
4 packets output, 240 bytes, 0 underruns
0 output errors, 1 interface resets
0 unknown protocol
*Aug 1 02:36:36.799: TTY0: pause timer type 1 (OK)
*Aug 1 02:36:36.799: TTY0: resume timer type 1 (OK) drops
Router#
*Aug 1 02:36:39.283: Ce0 DDR: re-enable timeout
*Aug 1 02:36:39.283: DDR: Dialer Watch: watch-group = 1
*Aug 1 02:36:39.283: DDR: network 192.168.1.254/0.0.0.255 DOWN,
*Aug 1 02:36:39.283: DDR: primary DOWN
*Aug 1 02:36:39.283: Ce0 DDR: Attempting to dial lte
*Aug 1 02:36:39.283: CHAT3: Attempting async line dialer script
*Aug 1 02:36:39.283: CHAT3: Dialing using Modem script: lte & System script: none
*Aug 1 02:36:39.283: CHAT3: process started
*Aug 1 02:36:39.283: CHAT3: Asserting DTR
*Aug 1 02:36:39.283: CHAT3: Chat script lte started
*Aug 1 02:36:53.363: CHAT3: Chat script lte finished, status = Carrier dropped
*Aug 1 02:36:53.363: TTY3: Line reset by "Async dialer"
*Aug 1 02:36:53.363: Ce0 DDR: disconnecting call
*Aug 1 02:36:53.363: TTY3: Modem: (unknown)->HANGUP
*Aug 1 02:36:53.363: TTY3: no timer type 0 to destroy
*Aug 1 02:36:53.363: TTY3: no timer type 1 to destroy
*Aug 1 02:36:53.363: TTY3: no timer type 3 to destroy
*Aug 1 02:36:53.363: TTY3: no timer type 4 to destroy
*Aug 1 02:36:53.363: TTY3: no timer type 10 to destroy
*Aug 1 02:36:53.363: TTY3: no timer type 2 to destroy
*Aug 1 02:36:53.819: TTY3: dropping DTR, hanging up
*Aug 1 02:36:53.819: tty3: Modem: HANGUP->IDLE
*Aug 1 02:36:58.819: TTY3: restoring DTR
*Aug 1 02:36:59.819: TTY3: Always-on modem
*Aug 1 02:36:59.819: tty3: Modem: IDLE->READY
*Aug 1 02:37:00.879: %CISCO800-6-SIM_STATUS: SIM in slot 1 is present
Router#
Router#
*Aug 1 02:37:08.363: Ce0 DDR: re-enable timeout
*Aug 1 02:37:08.363: DDR: Dialer Watch: watch-group = 1
*Aug 1 02:37:08.363: DDR: network 192.168.1.254/0.0.0.255 DOWN,
*Aug 1 02:37:08.363: DDR: primary DOWN
*Aug 1 02:37:08.363: Ce0 DDR: Attempting to dial lte
*Aug 1 02:37:08.363: CHAT3: Attempting async line dialer script
*Aug 1 02:37:08.363: CHAT3: Dialing using Modem script: lte & System script: none
*Aug 1 02:37:08.363: CHAT3: process started
*Aug 1 02:37:08.363: CHAT3: Asserting DTR
*Aug 1 02:37:08.363: CHAT3: Chat script lte started
*Aug 1 02:37:28.363: CHAT3: Chat script lte finished, status = Connection timed out; remote host not responding
*Aug 1 02:37:28.363: TTY3: Line reset by "Async dialer"
*Aug 1 02:37:28.363: Ce0 DDR: disconnecting call
*Aug 1 02:37:28.363: TTY3: Modem: (unknown)->HANGUP
*Aug 1 02:37:28.363: TTY3: no timer type 0 to destroy
*Aug 1 02:37:28.363: TTY3: no timer type 1 to destroy
*Aug 1 02:37:28.363: TTY3: no timer type 3 to destroy
*Aug 1 02:37:28.363: TTY3: no timer type 4 to destroy
*Aug 1 02:37:28.363: TTY3: no timer type 10 to destroy
*Aug 1 02:37:28.363: TTY3: no timer type 2 to destroy
*Aug 1 02:37:28.819: TTY3: dropping DTR, hanging up
*Aug 1 02:37:28.819: tty3: Modem: HANGUP->IDLE
*Aug 1 02:37:33.819: TTY3: restoring DTR
*Aug 1 02:37:34.819: TTY3: Always-on modem
*Aug 1 02:37:34.819: tty3: Modem: IDLE->READY
*Aug 1 02:37:36.759: %CISCO800-2-MODEM_UP: Cellular0 modem is now UP.
*Aug 1 02:37:37.035: %CISCO800-6-SIM_STATUS: SIM in slot 0 is not present
*Aug 1 02:37:38.139: %CISCO800-2-MODEM_DOWN: Cellular0 modem is now DOWN.
*Aug 1 02:37:43.363: Ce0 DDR: re-enable timeout
*Aug 1 02:37:43.363: DDR: Dialer Watch: watch-group = 1
*Aug 1 02:37:43.363: DDR: network 192.168.1.254/0.0.0.255 DOWN,
*Aug 1 02:37:43.363: DDR: primary DOWN
*Aug 1 02:37:43.363: Ce0 DDR: Attempting to dial lte
*Aug 1 02:37:43.363: CHAT3: Attempting async line dialer script
*Aug 1 02:37:43.363: CHAT3: Dialing using Modem script: lte & System script: none
*Aug 1 02:37:43.363: CHAT3: process started
*Aug 1 02:37:43.363: CHAT3: Asserting DTR
*Aug 1 02:37:43.363: CHAT3: Chat script lte started
*Aug 1 02:37:48.035: %CISCO800-6-SIM_ACTIVATION: SIM in slot 1 is being activated. Please wait for modem to come UP.
*Aug 1 02:38:03.363: CHAT3: Chat script lte finished, status = Connection timed out; remote host not responding
*Aug 1 02:38:03.363: TTY3: Line reset by "Async dialer"
*Aug 1 02:38:03.363: Ce0 DDR: disconnecting call
*Aug 1 02:38:03.363: TTY3: Modem: (unknown)->HANGUP
*Aug 1 02:38:03.363: TTY3: no timer type 0 to destroy
*Aug 1 02:38:03.363: TTY3: no timer type 1 to destroy
*Aug 1 02:38:03.363: TTY3: no timer type 3 to destroy
*Aug 1 02:38:03.363: TTY3: no timer type 4 to destroy
*Aug 1 02:38:03.363: TTY3: no timer type 10 to destroy
*Aug 1 02:38:03.363: TTY3: no timer type 2 to destroy
*Aug 1 02:38:03.819: TTY3: dropping DTR, hanging up
*Aug 1 02:38:03.819: tty3: Modem: HANGUP->IDLE
*Aug 1 02:38:08.819: TTY3: restoring DTR
*Aug 1 02:38:09.819: TTY3: Always-on modem
*Aug 1 02:38:09.819: tty3: Modem: IDLE->READY
*Aug 1 02:38:12.915: %CISCO800-2-MODEM_UP: Cellular0 modem is now UP.
*Aug 1 02:38:18.363: Ce0 DDR: re-enable timeout
*Aug 1 02:38:18.363: DDR: Dialer Watch: watch-group = 1
*Aug 1 02:38:18.363: DDR: network 192.168.1.254/0.0.0.255 DOWN,
*Aug 1 02:38:18.363: DDR: primary DOWN
*Aug 1 02:38:18.363: Ce0 DDR: Attempting to dial lte
*Aug 1 02:38:18.363: CHAT3: Attempting async line dialer script
*Aug 1 02:38:18.363: CHAT3: Dialing using Modem script: lte & System script: none
*Aug 1 02:38:18.363: CHAT3: process started
*Aug 1 02:38:18.363: CHAT3: Asserting DTR
*Aug 1 02:38:18.363: CHAT3: Chat script lte started
*Aug 1 02:38:38.363: CHAT3: Chat script lte finished, status = Connection timed out; remote host not responding
*Aug 1 02:38:38.363: TTY3: Line reset by "Async dialer"
*Aug 1 02:38:38.363: Ce0 DDR: disconnecting call
*Aug 1 02:38:38.363: TTY3: Modem: (unknown)->HANGUP
*Aug 1 02:38:38.363: TTY3: no timer type 0 to destroy
*Aug 1 02:38:38.363: TTY3: no timer type 1 to destroy
*Aug 1 02:38:38.363: TTY3: no timer type 3 to destroy
*Aug 1 02:38:38.363: TTY3: no timer type 4 to destroy
*Aug 1 02:38:38.363: TTY3: no timer type 10 to destroy
*Aug 1 02:38:38.363: TTY3: no timer type 2 to destroy
*Aug 1 02:38:38.819: TTY3: dropping DTR, hanging up
*Aug 1 02:38:38.819: tty3: Modem: HANGUP->IDLE
*Aug 1 02:38:43.819: TTY3: restoring DTR
*Aug 1 02:38:44.819: TTY3: Always-on modem
*Aug 1 02:38:44.819: tty3: Modem: IDLE->READY
*Aug 1 02:38:53.363: Ce0 DDR: re-enable timeout
*Aug 1 02:38:53.363: DDR: Dialer Watch: watch-group = 1
*Aug 1 02:38:53.363: DDR: network 192.168.1.254/0.0.0.255 DOWN,
*Aug 1 02:38:53.363: DDR: primary DOWN
*Aug 1 02:38:53.363: Ce0 DDR: Attempting to dial lte
*Aug 1 02:38:53.363: CHAT3: Attempting async line dialer script
*Aug 1 02:38:53.363: CHAT3: Dialing using Modem script: lte & System script: none
*Aug 1 02:38:53.363: CHAT3: process started
*Aug 1 02:38:53.363: CHAT3: Asserting DTR
*Aug 1 02:38:53.363: CHAT3: Chat script lte started
*Aug 1 02:39:13.363: CHAT3: Chat script lte finished, status = Connection timed out; remote host not responding
*Aug 1 02:39:13.363: TTY3: Line reset by "Async dialer"
*Aug 1 02:39:13.363: Ce0 DDR: disconnecting call
*Aug 1 02:39:13.363: TTY3: Modem: (unknown)->HANGUP
*Aug 1 02:39:13.363: TTY3: no timer type 0 to destroy
*Aug 1 02:39:13.363: TTY3: no timer type 1 to destroy
*Aug 1 02:39:13.363: TTY3: no timer type 3 to destroy
*Aug 1 02:39:13.363: TTY3: no timer type 4 to destroy
*Aug 1 02:39:13.363: TTY3: no timer type 10 to destroy
*Aug 1 02:39:13.363: TTY3: no timer type 2 to destroy
*Aug 1 02:39:13.823: TTY3: dropping DTR, hanging up
*Aug 1 02:39:13.823: tty3: Modem: HANGUP->IDLE
*Aug 1 02:39:18.823: TTY3: restoring DTR
*Aug 1 02:39:19.823: TTY3: Always-on modem
*Aug 1 02:39:19.823: tty3: Modem: IDLE->READY
*Aug 1 02:39:28.363: Ce0 DDR: re-enable timeout
*Aug 1 02:39:28.363: DDR: Dialer Watch: watch-group = 1
*Aug 1 02:39:28.363: DDR: network 192.168.1.254/0.0.0.255 DOWN,
*Aug 1 02:39:28.363: DDR: primary DOWN
*Aug 1 02:39:28.363: Ce0 DDR: Attempting to dial lte
*Aug 1 02:39:28.363: CHAT3: Attemptinync line dialer script
*Aug 1 02:39:28.363: CHAT3: Dialing using Modem script: lte & System script: none
*Aug 1 02:39:28.363: CHAT3: process started
*Aug 1 02:39:28.363: DTR
*Aug 1 02:39:28.363: CHAT3: Chat script lte started
Router#
Router#ping 8.8.8.8
*Aug 1 02:39:37.471: TTY0: pause timer type 1 (OK).....
Router#
*Aug 1 02:39:47.471: TTY0: resume timer type 1 (OK)
*Aug 1 02:39:48.363: CHAT3: Chat script lte finished, status = Connection timed out; remote host not responding
*Aug 1 02:39:48.363: TTY3: Line reset by "Async dialer"
*Aug 1 02:39:48.363: Ce0 DDR: disconnecting call
*Aug 1 02:39:48.363: TTY3: Modem: (unknown)->HANGUP
*Aug 1 02:39:48.363: TTY3: no timer type 0 to destroy
*Aug 1 02:39:48.363: TTY3: no timer type 1 to destroy
*Aug 1 02:39:48.363: TTY3: no timer type 3 to destroy
*Aug 1 02:39:48.363: TTY3: no timer type 4 to destroy
*Aug 1 02:39:48.363: TTY3: no timer type 10 to destroy
*Aug 1 02:39:48.363: TTY3: no timer type 2 to destroy
*Aug 1 02:39:48.823: TTY3: dropping DTR, hanging up
07-31-2022 11:58 PM
try and power cycle the modem:
Router#conf t
Router(config)#service internal
Router#test cellular 0 modem-power-cycle
08-01-2022 12:59 AM
this commands not support on this router
08-01-2022 01:11 AM
'service internal' is a hidden command, just type it in config mode and press <ENTER>...
08-01-2022 12:11 AM
I have seen issue with those routers where they do not connect when upgraded to newer ios. Try downgrading to 15.2
John
08-01-2022 04:41 AM
still not working...i try another sim for diffrent service provider its work..
i try to contact my service provider not luck
05-17-2023 08:45 PM
this means that the apn settings on the router match that of the second provider. find out the apn of the first provider and configure it then have it attached to the controller.
08-01-2022 05:24 AM
Check Cisco Recommend Config,
>>>>chat-script lte<<<<< this important
08-02-2022 12:10 AM
i think the problem that the modem mc7710 doest support the frequencies of my service provider
08-02-2022 01:14 AM
do you config the router as I suggest ?
08-02-2022 08:13 PM
Yes..its the same
