Cisco 819G-4G-V-K9 4G configuration (Verizon+SIM card)
Kyle C Barnes
Hi!
We've picked up a Cisco 819 to play around with the cellular capabilities (SDP down the road).
I have an unlocked Verizon SIM card installed..
yourname#sh cellular 0 security
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of CHV1 Retries remaining = 3
yourname#sh cellular 0 profile
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = VZWINTERNET
Authentication = NONE
Username:
Password:
I'm reading all kinds of configuration setups....and it all does not seem to fit our situation.  The main resource I've used is this one:
http://www.cisco.com/en/US/docs/routers/access/interfaces/software/feature/guide/EHWIC-4G-LTESW.pdf
Does anyone have some guidance on moving forward with an unlocked SIM card to get the modem configured?  Do I need to work with Verizon at all, or does having the unlocked SIM card suffice?
Thanks!
I'm kind of in the same boat.  Although I've noticed that the cell portion seems to be working as I can actually send a text to the router from my phone and it receives it.  The only problem is that I'm not getting an ip address on the cell 0 interface.
Check out my blog post for this issue:
http://kylesnetworkingblog.blogspot.com/2013/12/cisco-819g-4g-v-k9-verizon-4g-wan.html
I ended up getting it resolved.  The issue (for me) was that I didn't configure line 3 with the dialer script and the "modem InOut."
