Cisco 831 can't ping gateway
picotable
Hi:  I'm new to this and I'm trying to set up a stub network with a DMZ on a
Cisco 831.  I haven't set up NAT or any access lists yet.  The router can ping
everything in all three segments-- WAN, LAN, DMZ.  A PC in (ether2) can
ping all router interfaces, but cannot ping PC or gateway in the WAN segment.  A PC in WAN
segment can ping gateway and 831 WAN interface, but no inside interfaces.  Can anyone
point out my mistake please?
Cisco831#show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  192.168.40.1            -   0011.20da.ee3f  ARPA   Ethernet0
Internet  192.168.30.1            -   0011.20da.ee3f  ARPA   Ethernet2
Internet  192.168.30.10           2   00a0.cc79.b659  ARPA   Ethernet2
Internet  172.16.2.10             -   0011.20da.ee40  ARPA   Ethernet1
Internet  172.16.2.5              4   001d.60d1.6f2a  ARPA   Ethernet1
Internet  172.16.2.1              0   0018.3a08.ced8  ARPA   Ethernet1
Cisco831#show ip route
Gateway of last resort is 172.16.2.1 to network 0.0.0.0
C    192.168.30.0/24 is directly connected, Ethernet2
C    192.168.40.0/24 is directly connected, Ethernet0
C    172.16.0.0/16 is directly connected, Ethernet1
S*   0.0.0.0/0 [1/0] via 172.16.2.1
Cisco831#show run
Building configuration...
Current configuration : 1455 bytes
version 12.3
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Cisco831
boot-start-marker
boot-end-marker
memory-size iomem 5
username PICOMETER
no aaa new-model
ip subnet-zero
no ip domain lookup
ip ids po max-events 100
no ftp-server write-enable
password encryption aes
interface Ethernet0
description inside LAN segment
ip address 192.168.40.1 255.255.255.0
no cdp enable
interface Ethernet1
description internet WAN segment
ip address 172.16.2.10 255.255.0.0
duplex auto
no cdp enable
interface Ethernet2
description DMZ LAN segment
ip address 192.168.30.1 255.255.255.0
no cdp enable
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet3
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.2.1
ip http server
no ip http secure-server
no cdp run
control-plane
line con 0
exec-timeout 120 0
no modem enable
transport preferred all
transport output all
stopbits 1
line aux 0
line vty 0 4
exec-timeout 120 0
password 7 11031008161606050A
login
transport input all
scheduler max-task-time 5000
end
show ip int br
Interface                  IP-Address      OK? Method Status
Protocol
Ethernet0                  192.168.40.1    YES manual up
up
Ethernet1                  172.16.2.10     YES NVRAM  up
up
Ethernet2                  192.168.30.1    YES NVRAM  up
up
FastEthernet1              unassigned      YES unset  up
up
FastEthernet2              unassigned      YES unset  administratively down
down
FastEthernet3              unassigned      YES unset  administratively down
down
FastEthernet4              unassigned      YES unset  up
up
5 Accepted Solutions
paolo bevilacqua
Check that PCs have valid default routes.
Jim
The information that you have supplied has been helpful. While it is not quite enough to definitely identify the problem it helps me to make a guess at the problem.
I have looked through the router config and I do not see any issues there that would produce these symptoms. I have looked at the output from route print from the PC and it looks to be ok. I do not believe that the problem is with either the 831 router or this PC.
My guess is that the issue is with the PC in the WAN subnet and with the Gateway for the WAN subnet. My guess is that the PC has its gateway configured to be the WAN gateway and that the WAN gateway does not have a route for the 192.168.30.0 subnet. My guess is that when your PC attempts to ping the PC in the WAN that the ping gets to the WAN PC and that it attempts to respond. But since its gateway is the WAN gateway it forwards its ping response to the WAN gateway. And if the WAN gateway does not have 192.168.30.0 in its route table then it can not forward the ping reponse.
Can you check the WAN PC and confirm that its configured gateway is the WAN gateway? And can you check the WAN gateway and confirm that it does not have a route for 192.168.30.0?
Rick
Rick
Does the gateway router '172.16.2.1' have a route to the 192.168.30.0 network?  If not try adding a route and see what happens.
Check 172.16.2.1 also.
And disable firewall on all PCs.
Good to hear and good luck on the DMZ setup. Thanks for the rating also!!
8 Replies 8
paolo bevilacqua
Still Can't ping 172.16.2.1...
  From  PC  192.168.30.10
Any clues?
Jim
Rick
Rick
Success
     Thanks to the support community for combining forces. The instincts were good regarding the gateway—Thanks to Richard Burts, Dialer String and p. bevilacqua.
                Apparently the gateway router, which is a proprietary design/configuration of the ISP (Westell 6100), was somehow incapable of acting in this network scenario.  Actually, I was unable to obtain its routing table, which lead me to the ISP support services.  They informed me of its deficiencies, without going into detail, and recommended configuring the device in bridge mode. I then inserted a run-of-the-mill router at R1 (Linksys BEFSR41) as the gateway router which had the advantage of being something familiar to the support tech, who was able to configure it with their bridge device to the point that I had a hard LAN interface. I then arranged the network as in the diagram below.
               The rest was inserting the route to the 30.0 network and then strangely, everything started pinging (a great feeling in its own right) including the 40.0 network in ether0.  Apparently there is a sharing of electrical resources between ether2 and ether0 in the 831:
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xr/dmz_port.pdf
•Because the media-independent interface, which connects the router's LAN interface to the Marvel switch, operates only at 10 Mbps, inter-LAN routing speed between Ethernet 0 and Ethernet 2 interfaces will be limited to a maximum of 10 Mbps.
•Because Ethernet 0 and Ethernet 2 interfaces share the same Tx/Rx rings, buffer pools, and communication controller, the output of some of the commands such as show controller and show buffers may be similar.
•The MAC address for the Ethernet 2 interface will be same as that for the Ethernet 0 interface.
     I inserted a route to the 40.0 network to no apparent detriment.  If anyone has a good reference, I'd like to learn more about the architecture level involving "Tx/Rx rings, buffer pools, and communication controller" etc.
Now it's onward and upward to the DMZ configuration.  Thanks again and wish me luck!
R1 routing table
Cisco 831 routing table
picotable
For   PC_192.168.30.10
Is there something missing or present that causes this?  Metric?
