Cisco 831 Configuration help
joegrotjohn
I am setting my first cisco router an 831. I will have a subnet of 8 ip address with 6 useable. I have two firewalls that need static IP's and an application server that will need a static IP. Can or does anyone have an example of a config for this situation? I have always had the ISP set this up for me but would like to know how to do it myself. Any help would be great.
spremkumar
Level 9
Level 9
hi
do revert back whats ther real idea behind putting 2 firewalls out there in your network ? is there some kinda reduandcy you have marked out there with the firewalls ? also idea behind bringing in the servers in the public ip block ??
Whats the firewall model you are having ?
regds
One Firewall is for our internal protection, the second is provided by a vendor (we have a VPN to thier site) they require full control of the VPN/Firewall. The server that sits on a public IP will more then likly get moved into the DMZ once I get enough time.
