Cisco 837 ADSL router interface Ethernet2 down and can’t bring it up.
marianodaniel
Hello! I am one of the poor sods stuck with this kind of complex & old router model.
I managed to assign an ip address to Ethernet2, however, I can´t seem to find a way to bring the interface up.
Anyone care to help?
I´ve been struggling with it for two days, and although fun and challenging! I need the router working.
My idea is to access the web gui, configure & secure it, and then keep exploring IOS.
Thanks a lot in advance!
21 Replies 21
odd, again...
Try and disable/reenable the DHCP service:
cisco837#conf t
cisco837(config)#no service dhcp
cisco 837(config)#service dhcp
Still no good. What’s the best take to delete all configs on the router and start from scratch?
Current config:
cisco837#show configuration
Using 1125 out of 131072 bytes
version 12.4
no service pad
hostname cisco837
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no ip dhcp use vrf connected
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 8.8.8.8
   domain-name reload
ip cef
partition flash 2 11 1
interface Ethernet0
 no ip address
 shutdown
 hold-queue 100 out
interface Ethernet2
interface Ethernet0
 no ip address
 shutdown
 hold-queue 100 out
interface Ethernet2
 ip dhcp client client-id Ethernet2
 ip dhcp client lease 365 0 0
 hold-queue 100 out
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
 dsl operating-mode auto
interface FastEthernet1
 duplex auto
 speed auto
interface FastEthernet2
 duplex auto
 speed auto
interface FastEthernet3
 duplex auto
 speed auto
 duplex auto
 speed auto
 duplex auto
 speed auto
interface FastEthernet4
 duplex auto
 speed auto
no ip http server
no ip http secure-server
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
scheduler max-task-time 5000
end
cisco837#wr erase
then reload, that will wipe the entire config.
Thank you! I have and it erased everything. I’ve gone the simple way, setup the dhcp, but still not getting a ping response. Darn.
For the dhcp:
#ip dhcp pool LAN
#192.168.0.1 255.255.255.0
#network 192.168.0.1 255.255.255.0
#default-router 192.168.1.1
#dns-server 8.8.8.8
For the Interface
#inter e2
#ip address 192.168.1.1 255.255.255.0
#no shutdown
nterface is up, not sure why not picking up *sigh*
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  down                  down
FastEthernet3              unassigned      YES unset  down                  down
FastEthernet4              unassigned      YES unset  up                    up
Ethernet0                  unassigned      YES unset  administratively down down
ATM0                       unassigned      YES unset  administratively down down
Ethernet2                  192.168.1.1     YES manual up                    up
cisco837#
that doesn't look right (0 and 1 are reversed):
For the dhcp:
#ip dhcp pool LAN
#network 192.168.0.1 255.255.255.0 <-- that needs to be network 192.168.1.0
#dns-server 8.8.8.8
@Georg Pauwen thanks for replying! You did it! Thanks so much for the amazing help. Let’s explore this nice router and see what it can do. I will surely invest in a few Cisco Switches as well to start a home lab.
Thanks a lot again Georg, you are the best!
