Cisco 837 ADSL router with my new Server
reb999000
To All,
I am now using my 837 Router on my new Server and I have only made one change to the Global configuation mode, please veiw the input below:
ip dhcp pool DLSR
network 10.10.10.1 255.255.255.0
default-router 10.10.10.1
dns-server 10.10.10.2
(Note* I have only changed the ip address from 10.10.10.1 to 10.10.10.2)
I am getting the internet from the server but NOT from the clients. And I am making all my PCs as Clients.
I would be very greatful for any help in regards to this.
Bob.
cadet alain
Can you post your NAT config along with access-list.
Alain
Cadet Alain,
Please find pasted my current NAT configs for your further information:
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 10.10.10.0 0.0.0.255
Bob.
your dhcp pool syntax is not correct it should be network 10.10.10.0 255.255.255.0
and if it is a ststic mapping then it is incorrect too.
Alain
Cadet Alain,
As I have moved and connected up my 837 Router onto my new Server (Which is running Win 2003 Server OS) and for this I must completely remove DHCP from the router??
And for this, my Workstations are now Clients and I am using Static IP Adresses on the entire network.
Here is a few inputs in regards to DHCP:
ip dhcp use vrf connected
ip dhcp pool DSLR
dns-server 10.10.10.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer 0
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source list 1 interface Dialer 0 overload
As for some reason the moderators now forbids members to paste inputs from Cisco equipement.
Bob.
