Cisco 837 Problem
victorblue
I have a cisco 837, I am trying to put factory defaults settings but when I finish , I can?t reach the router ip (it should be 10.10.10.1 ?),I can connect to router only by com port, and I don?t know what is the problem. Please help
Router>enable
Router#conf t
Router(config)#interface e0
Router(config-if)#ip address 10.10.10.1 255.255.255.0
Router(config-if)#no shut
Router(config-if)#exit
Router(config)#exit
Router#copy run start
Type the commands as you see them and pay attention to the prompts. Im not a big fan of the gui, you might want to learn how to use the cli.
8 Replies 8
smothuku
Level 7
Level 7
Hi Victor ,
Are you getting any messages after resetting it to factory default settings..
Plz check the below link for how to reset a router to factory defaults.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/products_tech_note09186a00802017a1.shtml
satish
I do first method, and when I trying to connect to router via explorer I can?t reach router.
If I do 2 method I can?t reach the router too.
When I put some command in hyperterminal I get next message:
Translating "controllers"...domain server (255.255.255.255)
% Unknown command or computer name, or unable to find computer address
How I can put 10.10.10.1 in the server ip to connect it via Explorer ?
Hi Victor ,
Plz check the below link for blocking the message which is apprearing on the consloe.
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00802015c8.shtml
satish
Hi and thanks for reply,
When I do runnin-config I get :
Current configuration : 840 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
resource policy
et2, chan
!d
interface Ethernet0
no ip address
shutdown
hold-queue 100 out
interface Ethernet2
no ip address
shutdown
hold-queue 100 out
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
ip http server
no ip http secure-server
control-plane
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
I config my pc with 10.10.10.4 but I can?t connect to router.
How I get that the router ip be 10.10.10.1 and get config my router via http?
I don?t Know how configure it via commands.
Kind Regards
try below. replace X's with IP address for eth0. Use same IP range and subnet as assigned to your PC.
interface Ethernet0
description # Connected to you lan#
ip address XXX.XX.XX.X 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1348
hold-queue 100 out
no shut
how can I do it via command?
I do not know
Router>enable
Router#conf t
Router(config)#exit
Dear ,
Thanks a lot for all, my router is up and working again.
Many thanks and Regards
