03-23-2006 09:48 PM - edited 03-03-2019 12:09 PM
Just wondering if anyone knows if the Cisco 837 can be configured for a 512/512 SDSL connection? The SDSL connection is just a bridge connection (/30) where you get one static IP and the other static IP is the gateway on Telstra's end.
If the 837 can support a SDSL connection, does anyone have a config for it? Or would the config be the same as a ADSL bridge connection?
Thanks in advance.
03-24-2006 12:57 AM
I think the 878 supports SDSL (G.SHDSL). The 877 router supports ADSL2/ADSL2+ and is very similar to the 837.
03-24-2006 01:02 AM
We've used the 837 for 'symmetric' ADSL rates of up to 512k/512k.... However, the problem I see is that you are hoping to use this router for an SHDSL link - that is not possible with the 837 and as the previous poster mentioned, you will need to look at a different platform.
I have used the 828 and also the 1721 + WIC-1SHDSL on the Telstra network but I'm sure the newer platforms would work just as well...
Hope that helps - pls rate the post if it does.
Paresh
03-26-2006 01:50 PM
Thanks for all your replies.
I'm using a standard bridge config on the 837 with pvc set to 8/35 but debug all is giving me weird results. Can anyone interpret the debug?
*Mar 1 00:02:33.043: ILMI(ATM0): Sending ilmiColdStart trap
*Mar 1 00:02:33.043: ILMI(ATM0): No ILMI VC found
*Mar 1 00:02:33.043: ILMI: Encapsulation error on o/g ILMI Pdu
*Mar 1 00:02:33.043: ILMI: Unable to Send Pdu out
*Mar 1 00:02:33.055: STP: opt: Bridge group 1: get ports: no free chunk available
*Mar 1 00:02:33.055: ATM0(O):
Here is a snip of the ATM interface.
interface ATM0
no ip address
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode auto
bridge-group 1
hold-queue 224 in
pvc 8/35
encapsulation aal5snap
