CISCO 837 set up problems
miccutajar
this is my first time with a cisco product.
i am installing a cisco 837 and am having a few problems.
When trying to set up the router to put in my WAN username and passord to log on to my ISP the router crashes. i take the following steps.
-type address in browser
-the CRWS (cisco router web setup java) launches
-i input my username and password into the specific boxes and then click save/apply
-the box appears with the blue line but when it gets the the end it just keeps going... the router has then hit a loop.
this is strage because when i change any other settings (for example, the routers ip on a LAN) and click apply the router is fine.
i have read somewhere that this router doesnt work well with the latest version on java (sun java).
does anyone know a decent version of JAVA i could use or another way i could configure the router?
thanks for any help
michael
spremkumar
Level 9
Level 9
hi
As an alternate and viable solution you can access your box using console port of the 837 router and you can start configuring as per your desire.
http://www.cisco.com/en/US/products/hw/routers/ps380/products_quick_start_chapter09186a008010e5b9.html
http://www.cisco.com/en/US/products/hw/routers/ps380/products_installation_guide_chapter09186a008010e5ae.html
i feel the above 2 links will help u out to get into the console and proceed further.
regds
