03-25-2008 03:07 PM - edited 03-03-2019 09:16 PM
I would like to know if it is possible to enable SNMP on a Cisco 857w in Server mode, and also what extra features this will open up on the router to troubleshoot with.
thanks.
Solved! Go to Solution.
03-25-2008 03:22 PM
The minimum config:
snmp-server community xxx
You don't do much troubleshooting with snmp, it is more a monitoring tool to get health status from a router and traffic statistics.
03-25-2008 03:22 PM
The minimum config:
