Cisco 857W FTP behind router problem
mattyp1980
I have recently purchased a Cisco 857W router for my home office and need to setup my Buffalo NAS FTP server behind it. I require remote access from my main office to the FTP server but can't seem to access it remotely, I have opened port 21 and created a NAT rule from inside to outside interface but still no joy. Has anyone got any knowledge of the procedure and if so could they please assist me, thanks.
paddyxdoyle
Level 6
Level 6
How is your NAT configured, something like:
# ip nat inside source static
internal interface
# ip nat inside
external interface
# ip nat outside
Are you seeing anything traffic being NATed
# debug ip nat
PJD
Hi thanks for your help I appreciate it, I am a Cisco newbie so to help answer your questions here is the relevant part of the config file...
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
bridge-group 1
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip inspect DEFAULT101 out
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname ********************
ppp chap password 7 ******************
interface BVI1
description $ES_LAN$$FW_INSIDE$
ip address 192.168.0.1 255.255.255.0
ip access-group 100 in
ip nat inside
ip tcp adjust-mss 1452
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 192.168.0.2 21 interface Dialer0 21
ip access-list extended sdm_dialer0_in
remark SDM_ACL Category=1
permit ip any any
logging trap debugging
logging 192.168.0.1
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp host 62.241.163.200 eq domain any
access-list 101 permit udp host 62.241.162.200 eq domain any
access-list 101 remark BUFFALO FTP
access-list 101 permit tcp any any eq ftp log
access-list 101 deny ip 192.168.0.0 0.0.0.255 any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any log
dialer-list 1 protocol ip permit
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport preferred all
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
transport output all
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
