Cisco 860
tarikba
Please help!
I have following problem: This is situation on current Router. I have idea to put another IOS, and I tftp downloaded IOS from working router.
How can I delete this corrupted IOS ro replace it or what to do?
I'm new in this field and I want to learn and progress...
This is current situation...:
Error : compressed image checksum is incorrect 0xED17CE85
Expected a checksum of 0x57FDDE85
18 Replies 18
Leo Laohoo
Delete a file: delete /f /r flash:filename.ext
File system is not ready to use.
Please reset before access file system
rommon 2 > dir
I tried it, and this is displayed:
rommon 3 > flash:
monitor: command "flash:" not found
rommon 4 > dev
Devices in device table:
id name
flash: flash
And when I tried to tftpdnld command nothing happened; maybe I make mistake, but i did set environment like this:
rommom 1> IP_ADDRESS=192.168.1.2
rommon 2> IP_SUBNET_MASK=255.255.255.0
rommon 3> DEFAULT_GATEWAY=192.168.1.1
rommon 4> TFTP_SERVER=192.168.1.1
rommon 5> TFTP_FILE=c860vae-advsecurityk9-mz.152-4.M5.bin
after that nothing...
A moment ago I tried and:
rommon 8 > IP_ADDRESS=192.168.1.2
rommon 9 > IP_SUBNET_MASK=255.255.255.0
rommon 10 > DEFAULT_GATEWAY=192.168.1.1
rommon 11 > TFTP_SERVER=192.168.1.1
rommon 12 > TFTP_FILE=c860vae-advsecurityk9-mz.152-4.M5.bin
rommon 13 > tftpdnld
Please reset before executing this command
rommon 14 >
Am I doing something wrong?
rommon > reset
rommon >IP_ADDRESS=192.168.1.2
rommon > IP_SUBNET_MASK=255.255.255.0
rommon  > DEFAULT_GATEWAY=192.168.1.1
rommon  > TFTP_SERVER=192.168.1.1
rommon > TFTP_FILE=c860vae-advsecurityk9-mz.152-4.M5.bin
rommon  > tftpdnld
Just type a RESET command and configure again the as above details.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Just tried again, only this time with '-r':
rommon 8 > tftpdnld -r
IP_ADDRESS: 192.168.1.2
IP_SUBNET_MASK: 255.255.255.0
DEFAULT_GATEWAY: 192.168.1.1
TFTP_SERVER: 192.168.1.1
TFTP_FILE: c860vae-advsecurityk9-mz.152-4.M5.bin
TFTP_DESTINATION: flash:
DOWNLOAD_PORT: 0 (LAN FE 0..3, LAN GE 4 for ADV K9, WAN GE 5)
TFTP_VERBOSE: Progress
TFTP boot exit: File not found
rommon 9 >
And now this:
rommon 9 > tftpdnld -ur
Loading 192.168.1.1:c860vae-advsecurityk9-mz.152-4.M5.bin ...
Loading failed.:
TFTP load exit: Timeout occured
And:
monitor: command "boot" aborted due to user interrupt
rommon 1 > IP_ADDRESS=192.168.1.2
rommon 2 > IP_SUBNET_MASK=255.255.255.0
rommon 3 > DEFAULT_GATEWAY=192.168.1.1
rommon 4 > TFTP_SERVER=192.168.1.1
rommon 5 > TFTP_FILE=c860vae-advsecurityk9-mz.152-4.M5.bin
rommon 6 > tftpdnld
System Bootstrap, Version 15.1(4r)M2, RELEASE SOFTWARE (fc1)
Copyright (c) 2011 by cisco Systems, Inc.
C860VAE advanced k9 platform with 256 MB of main memory
Booting flash:/c860vae-advsecurityk9-mz.152-4.M5.bin
boot: Launch entrypt: 0x80800000
Error : compressed image checksum is incorrect 0xF517CAC5
Now the issue has changed to "TFTP load exit: Timeout occured"
Is the TFTP server started? Is System Firewall off or TFTP ports allowed?
Deepak Kumar,
Does the 860 have a USB port or not?
Yes, there is USB port.
What should I do?
IOS is on USB also... Is there any requirements regarding USB?
Stick the USB flash drive into the router's USB port. Issue the command "dir usbflash0:".
If the contents appear, then use the command "boot usbflash0:IOS_filename.bin" to boot the file.
Nothing unless later
Somehow I find out to input confreg 0x0, and after that all commands(dir, boot, etc) worked
Thank You very much...
This was a long fight...
later today I intend to change IOS on another Router since We had two with corrupted IOS
Had the same problem, and can confirm this solved it.
Do you have a valid Image in the TFTP server root (Home) directory?
Deepak Kumar,
