Cisco 861 license issue
s.heller
Hello everybody,
I obtained and installed a temporary Advanced IP Services license for a Cisco 861 router.  The license shows as active but not in use.  I cannot get the router to use this license.
Here is the output of some CLI commands:
Router#
Router#sh lic all
License Store: Primary License Storage
StoreIndex: 0   Feature: advsecurity                       Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
StoreIndex: 1   Feature: advipservices                     Version: 1.0
        License Type: Evaluation
        License State: Active, Not in Use, EULA accepted
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
        License Priority: Low
Router#
Router#sh lic feature
Feature name             Enforcement  Evaluation  Subscription   Enabled
advsecurity              no           no          no             yes
Router#
Router#sh ver
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO861-K9           FTX155555TV
License Information for 'c860-data'
    License Level: advsecurity   Type: Permanent
    Next reboot license Level: advsecurity
How can I get access to the Advanced IP Services features?
Thanks in advance
Is Adv IP Services a permissible upgrade for the 860 series?
I've had a brief glance at the following, and it would appear to suggest otherwise:
http://www.cisco.com/en/US/prod/collateral/routers/ps380/qa_c67_459785.html
Advanced Security: This is the default feature set and hence the default license  (preinstalled at factory) for the Cisco 860, 880 Data, and IAD880  platforms.
Advanced IP Services: This is an upgrade option for the Cisco 880 data or IAD platforms, and is the default feature set for Cisco 880 SRST.
8 Replies 8
Reza Sharifi
Did you install the license successfully?
Below line shows that you have to reboot the router for  the advsecurity to take effect
Reza, thanks for the reply.
The router came with the advsecurity feature license. I am trying to access the advipservices feature set.
The temporary advipservices license I installed showed as installing properly. I have reobooted the router.
I have tried to change the prioity of the licenses with no luck and I have tried clearing the advsecurity license with no luck.
kmccourt
I'm not sure about the 861, but on a 1921 ISR you can use the 'license boot module' command, e.g.
Cisco-1921(config)#license boot module c1900 technology-package  ?
   datak9      data technology
   securityk9  security technology
Hi k,
The  861 has the "license boot module" command but there is no valid data for it.
Router(config)#license boot modul?
module
Router(config)#license boot module ?
% Unrecognized command
Thanks for the reply.
k,
You are absolutely right.  Bad assumptions on my part.
Thank you for setting me straight.
But I think the point of the discussion is to active a temporary "license adv. ip serv.", that is possible on all other routers.
Ziga M
I have the same router and I was missing QOS - WRED feature... then I saw on Cisco Feature Navigator, that this feature is not supported on this router. What exactly are you missing? Maybe CFN can help...
On link bellow, someone pointed that if you need something special, you can obtain licence, but I somehow doubt that...
https://supportforums.cisco.com/message/3030929
