Cisco 861 WAN changed from DHCP to Static IP and now can't ping the internet.
eceflyboy
My old office uses Cisco 861 as a VPN router, with the WAN side setup to receive a dynamic IP assigned by Time Warner cable.  Now we switched to a new office, with TowerStream which provide 4G SLA'ed 10Mbit service with static IP, and I get a Cat 5 ethernet down from it.
So all I did, was to go my "interface FastEthernet4", and typed
ip address 173.243.123.123 255.255.255.252.
Changed speed to "speed 100" and "full-duplex" (as instructed by the ISP).
I also did "ip default-gateway 173.243.123.124", which is the default gate way assigned by the ISP.
I also typed "ip name-server 64.17.123.123" to setup the new DNS, am I doing anything wrong?  I can't even use the router to ping google, but if I connect the laptop directly to the outside line, then it works, so I know the outside line is good.
Am I not doing something right?  Why can't I connect to the internet?  I wasted several hours already trying everything in my book to trouble shoot a supposedly very simple configuration change.  Do I need to change something related to NAT when changing to Static IP?  My NAT was working just fine before when under DHCP.
Thanks for the help!
The below is my full config (some IPs changed to preserve anonymity):
Building configuration...
Current configuration : 16628 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname PureGate
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 51200 informational
enable secret 5 adsfasdf
enable password 7 asdfasdfdasf
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
clock timezone PCTime -8
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-1245995727
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1245995727
revocation-check none
rsakeypair TP-self-signed-1245995727
crypto pki trustpoint test_trustpoint_config_created_for_sdm
subject-name e=sdmtest@sdmtest.com
revocation-check crl
crypto pki certificate chain TP-self-signed-1234213421342134
certificate self-signed 01
  adsfasdfadfasdfasdfasf
  quit
crypto pki certificate chain test_trustpoint_config_created_for_sdm
no ip source-route
ip dhcp pool ccp-pool1
   import all
   network 10.2.2.0 255.255.255.0
   default-router 10.2.2.1
   dns-server 10.2.2.1
   domain-name local
ip dhcp update dns
ip cef
ip domain name local
ip host local ns ns.local
ip host trac.local 10.2.2.7
ip host ns.local 10.2.2.1
ip host-list members.dyndns.org
ip host-list mydomain.dyndns.org
ip name-server 64.17.123.124
ip name-server 4.2.2.1
ip ddns update method ccp_ddns
HTTP
  add http://mydomain:passwd@members.dyndns.org/nic/update?system=dyndns&hostname=passwd@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
  remove http://mydomain:passwd@members.dyndns.org/nic/update?system=dyndns&hostname=passwd@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
interval maximum 28 0 0 0
interval minimum 28 0 0 0
ip dhcp-client update dns server both
parameter-map type regex ccp-regex-nonascii
pattern [^\x00-\x80]
parameter-map type protocol-info msn-servers
server name messenger.hotmail.com
server name gateway.messenger.hotmail.com
server name webmessenger.msn.com
parameter-map type protocol-info aol-servers
server name login.oscar.aol.com
server name toc.oscar.aol.com
server name oam-d09a.blue.aol.com
parameter-map type protocol-info yahoo-servers
server name scs.msg.yahoo.com
server name scsa.msg.yahoo.com
server name scsb.msg.yahoo.com
server name scsc.msg.yahoo.com
server name scsd.msg.yahoo.com
server name cs16.msg.dcn.yahoo.com
server name cs19.msg.dcn.yahoo.com
server name cs42.msg.dcn.yahoo.com
server name cs53.msg.dcn.yahoo.com
server name cs54.msg.dcn.yahoo.com
server name ads1.vip.scd.yahoo.com
server name radio1.launch.vip.dal.yahoo.com
server name in1.msg.vip.re2.yahoo.com
server name data1.my.vip.sc5.yahoo.com
server name address1.pim.vip.mud.yahoo.com
server name edit.messenger.yahoo.com
server name messenger.yahoo.com
server name http.pager.yahoo.com
server name privacy.yahoo.com
server name csa.yahoo.com
server name csb.yahoo.com
server name csc.yahoo.com
username admin privilege 15 secret 5 asdfasdfasdfas
username user2 privilege 15 secret 5 adsfasdfasdfas
crypto logging ezvpn
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration address-pool local SDM_POOL_1
crypto isakmp client configuration group Company
key sdfgsdfgdsgsd
dns 4.2.2.1 4.2.2.2
pool SDM_POOL_1
acl 102
include-local-lan
max-users 100
netmask 255.255.255.0
banner ^CWelcome to company VPN!  Split tunneling is enabled.        ^C
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
set security-association idle-time 3600
set transform-set ESP-3DES-SHA
set isakmp-profile ciscocp-ike-profile-1
crypto ctcp port 10000
archive
log config
  hidekeys
ip tcp synwait-time 10
class-map type inspect match-any SDM_HTTPS
match access-group name SDM_HTTPS
class-map type inspect match-any SDM_SSH
match access-group name SDM_SSH
class-map type inspect match-any SDM_SHELL
match access-group name SDM_SHELL
class-map type inspect match-any sdm-cls-access
match class-map SDM_HTTPS
match class-map SDM_SSH
match class-map SDM_SHELL
class-map type inspect imap match-any ccp-app-imap
match  invalid-command
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
class-map type inspect match-any CCP-Voice-permit
match protocol h323
match protocol skinny
match protocol sip
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any SDM_IP
match access-group name SDM_IP
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
class-map type inspect match-any SDM_EASY_VPN_SERVER_TRAFFIC
match protocol isakmp
match protocol ipsec-msft
match class-map SDM_AH
match class-map SDM_ESP
class-map type inspect match-all SDM_EASY_VPN_SERVER_PT
match class-map SDM_EASY_VPN_SERVER_TRAFFIC
class-map type inspect ymsgr match-any ccp-app-yahoo-otherservices
match  service any
class-map type inspect msnmsgr match-any ccp-app-msn-otherservices
match  service any
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-cls-protocol-im
match protocol ymsgr yahoo-servers
match protocol msnmsgr msn-servers
match protocol aol aol-servers
class-map type inspect aol match-any ccp-app-aol-otherservices
match  service any
class-map type inspect match-all ccp-protocol-pop3
match protocol pop3
class-map type inspect pop3 match-any ccp-app-pop3
class-map type inspect match-all sdm-access
match class-map sdm-cls-access
match access-group 101
match  service text-chat
class-map type inspect match-all ccp-protocol-im
match class-map ccp-cls-protocol-im
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect http match-any ccp-app-httpmethods
match  request method bcopy
match  request method bdelete
match  request method bmove
match  request method bpropfind
match  request method bproppatch
match  request method connect
match  request method copy
match  request method delete
match  request method edit
match  request method getattribute
match  request method getattributenames
match  request method getproperties
match  request method index
match  request method lock
match  request method mkcol
match  request method mkdir
match  request method move
match  request method notify
match  request method options
match  request method poll
match  request method propfind
match  request method proppatch
match  request method put
match  request method revadd
match  request method revlabel
match  request method revlog
match  request method revnum
match  request method save
match  request method search
match  request method setattribute
match  request method startrev
match  request method stoprev
match  request method subscribe
match  request method trace
match  request method unedit
match  request method unlock
match  request method unsubscribe
class-map type inspect http match-any ccp-http-blockparam
match  request port-misuse im
match  request port-misuse p2p
match  req-resp protocol-violation
class-map type inspect match-all ccp-protocol-imap
match protocol imap
class-map type inspect match-all ccp-protocol-http
match protocol http
class-map type inspect http match-any ccp-http-allowparam
match  request port-misuse tunneling
interface Null0
no ip unreachables
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
ip dhcp client update dns server none
ip ddns update hostname members.dyndns.org
ip ddns update ccp_ddns1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
ip nat enable
ip virtual-reassembly
speed 100
full-duplex
interface Virtual-Template1 type tunnel
ip unnumbered Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 10.2.2.1 255.255.255.0
no ip redirects
no ip unreachables
ip flow ingress
ip flow egress
ip nat inside
ip tcp adjust-mss 1452
ip local pool SDM_POOL_1 10.2.2.100 10.2.2.254
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-top-talkers
top 100
sort-by bytes
cache-timeout 1000
ip dns server
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 10.0.0.12 80 interface FastEthernet4 999
ip access-list extended DYNDNS
permit tcp host 204.13.248.112 eq 443 any established log
ip access-list extended SDM_AH
remark CCP_ACL Category=1
permit ahp any any
ip access-list extended SDM_ESP
permit esp any any
ip access-list extended SDM_HTTPS
permit tcp any any eq 443
ip access-list extended SDM_IP
permit ip any any
ip access-list extended SDM_SHELL
permit tcp any any eq cmd
ip access-list extended SDM_SSH
permit tcp any any eq 22
ip access-list extended VNC
permit tcp any any eq 999
ip access-list extended kwVNC
remark kwVNC
permit tcp any host 10.0.0.19 eq 999
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 permit 10.2.2.0 0.0.0.255
access-list 2 permit 10.0.0.20
access-list 2 remark CCP_ACL Category=1
access-list 2 permit 10.0.0.21
access-list 3 remark CCP_ACL Category=1
access-list 3 permit 10.0.0.11
access-list 3 permit 10.0.0.15
access-list 4 remark CCP_ACL Category=1
access-list 4 permit 10.0.0.14
access-list 4 permit 10.0.0.16
access-list 10 remark CCP_ACL Category=16
access-list 10 permit 10.0.0.19
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark CCP_ACL Category=128
access-list 101 permit ip any any
access-list 102 remark CCP_ACL Category=4
access-list 102 permit ip 10.2.2.0 0.0.0.255 any
no cdp run
control-plane
banner exec ^C
3 Accepted Solutions
change
ip route 0.0.0.0 0.0.0.0 interface fastethernet 4
to
ip route 0.0.0.0 0.0.0.0 173.243.123.124
Regards.
Alain.
It was a test lab I had and I changed the default gate address on a router, and had
to ammend the DHCP. When I done this the ubuntu box had a new IP in the correct subnet but couldn't ping
a remote router or access the internet.
From the Ubuntu box, I removed all DHCP setting and set the nic to manual and manually entered a new IP address, subnet mask and default gateway, I then applied this to the box.
I then went back in and cleared these setting so that the IP address, Subnet mask and default gateway where blank. I may have hit ok and tried to apply these, I then went back in and made sure all setting where blank set the nic to DHCP applied and all worked.
The issue was on the ubuntu box for me, it just kept hold of the old default gateway for some strange reason.
to sniff traffic on linux bow use tcpdump.
Looking at your arp caches you haven't got the same mapping for 10.2.2.1 on linux and windows.
On windows the MAC is the MAC address of the Cisco router but on the linux box it corresponds to a netgear box.
Regards.
Alain.
29 Replies 29
Can you ping 173.243.123.124 from router?
I think the problem is with default gateway: try to run these commands:
no ip default-gateway 173.243.123.124
After that ping some external IP address from your router.
change
to
Regards.
Alain.
Wow, that worked!  Thanks!  Both:
and
allowed me to connect to the internet.  Is the later how you are supposed to connect to a "default gateway"?
Now the question is, what exactly does the "ip route" command do, and why was it necessary when configuring static IP?  How come I didn't previously need it when my ISP provided dynamic IP?
Thanks both again for saving me hours of agony.
"ip route x.x.x.x m.m.m.m g.g.g.g" adds a static route (x - network address, m - network mask, g - gateway address)
"ip route 0.0.0.0 0.0.0.0 IP" adds a default static route
Before you changed the configuration from dynamic to static IP configuration, ISP's DHCP server has send you all network parameteres, including default gateway address. After you've changed to static you have to enter all parameters manually, including default gateway address.
Usually DHCP servers sends IP address, network mask, default gateway address and DNS servers but can be configured to send many more parameters.
Thanks, that was very useful information.  So basically, adding a static route to either the gate way IP or FastEthernet4 is like adding a default gateway, one of the parameters that the DHCP usually provides right?
Now I have a different problem.  So my router is now configured for static IP, and the router acts as a DHCP client to assign IP to all my servers in my subnet.  The laptops are fine, but my Ubuntu Linux box is having trouble getting a default gate way assigned automatically by the Cisco 861.
Do you know why? Here is my Ubuntu's routing table
*** When it boots up, you can see there is no default route.
root@dev-server:/home/developer# netstat -nr
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
10.2.2.0        0.0.0.0         255.255.255.0   U         0 0          0 eth0
169.254.0.0     0.0.0.0         255.255.0.0     U         0 0          0 eth0
*** After I added a default route to my subnet 10.2.2.0:
root@dev-server:/home/developer# route add default gw 10.2.2.1
0.0.0.0         10.2.2.1        0.0.0.0         UG        0 0          0 eth0
However, my Linux box still can't ping the internet!  This is driving me crazy.
I suspect this section of code might be the culprit.
   import all      <-- this imports the DHCP info from the ISP right?  But now the ISP doesn't give any DHCP info, this is quite useless?  Taking it out doesn't seem to improve the situation.
   dns-server 10.2.2.1
   domain-name local
Any help would be deeply appreciated.  Tomorrow is Monday and this is a dev server in production that our devs needs to be able to use and upload files to the internet. Thanks!
cadet alain
Can you confirm your Linux Box is receiving an ip address with dhcp. type ifconfig -a and post here.
You can also do a debug ip dhcp server event on your router while renewing your lease.
Regards.
Alain.
Here is the result of the Linux server's "ifconfig":
root@dev-server:/home/myname# ifconfig
eth0      Link encap:Ethernet  HWaddr 00:26:b9:89:64:de
          inet addr:10.2.2.7  Bcast:10.2.2.255  Mask:255.255.255.0
          inet6 addr: fe80::226:b9ff:fe89:64de/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:7335 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3218 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1471319 (1.4 MB)  TX bytes:769095 (769.0 KB)
          Interrupt:16 Memory:da000000-da012800
eth1      Link encap:Ethernet  HWaddr 00:26:b9:89:64:df
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:17 Memory:dc000000-dc012800
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:390 errors:0 dropped:0 overruns:0 frame:0
          TX packets:390 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:156015 (156.0 KB)  TX bytes:156015 (156.0 KB)
eceflyboy
And the Ubuntu server in question resides on 10.2.2.7:
Here is the DHCP binding that I have assigned to it.
ip dhcp pool Trac
   host 10.2.2.7 255.255.255.0
   hardware-address 1234.1234.1234
   client-name dev-server
   dns-server 10.2.2.1
I tried to add a default gateway of 10.2.2.1 (my router's IP) but the Linux box still refuses to ping the outside world, while my router and my windows laptops are able to connect fine.  Our Mac users have reported instability and have to restart the mac's network interface once in a while.
This leads me to believe that some of the DHCP parameters are not passed correctly to the machines in the subnet; since the router no longer receives full DHCP parameters from the ISP, and what's passed down to the subnet is all manually configured parameters.
Is this MAC the real physical address? why did you change it? Can you try with client-identifier 0112.3412.3412.34  instead of hardware-address?
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfdhcp.html#wp1001108
Regards.
Alain.
oh, because I was reluctant to post our real mac addresses on the internet, but here are the real dhcp bindings for this server:
ip dhcp pool Trac
   hardware-address 0026.b989.64de
   dns-server 10.2.2.1
So is this Linux box getting an ip address with dhcp?  ----->  ifconfig
when you  do an ifconfig down then ifconfig up and at same time issue debug ip dhcp server event on router what happens ?
if you use regular pool and not a static binding is it the same?
Regards.
Alain.
Yes the Linux server is getting a DHCP IP correctly. Very strange.   And I did:
ip dhcp pool Trac
   dns-server 10.2.2.1
Because client-identifier wasn't working for me before, I thought we only use client-identifier for windows, and hardware-address for Linux boxes.
This all has worked before in our old office where we were getting a DHCP IP from the ISP.  I didn't think switching over to static IP address would be this painful....
If I don't use the DHCP binding pool the result is this when I restart the network interface:
root@dev-server:~$ netstat -nr
root@dev-server:~$ ifconfig -a
          RX packets:377 errors:0 dropped:0 overruns:0 frame:0
          TX packets:248 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:52842 (52.8 KB)  TX bytes:56350 (56.3 KB)
          RX packets:93 errors:0 dropped:0 overruns:0 frame:0
          TX packets:93 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:72867 (72.8 KB)  TX bytes:72867 (72.8 KB)
cadet alain
ok,
so can you traceroute to an external ip like 4.2.2.2
Regards.
Alain.
A small problem, the linux box doesn't have tracert installed, normally, all I need to do on Ubuntu is "aptitude install tracert", but I don't have the internet!
Let me try to see if I can get it some other way, but basically I get this error:
root@dev-server:~$ ping 4.2.2.1
PING 4.2.2.1 (4.2.2.1) 56(84) bytes of data.
From 10.2.2.1 icmp_seq=1 Destination Net Unreachable
