Cisco 861 WAN changed from DHCP to Static IP and now can't ping the internet.
eceflyboy
My old office uses Cisco 861 as a VPN router, with the WAN side setup to receive a dynamic IP assigned by Time Warner cable.  Now we switched to a new office, with TowerStream which provide 4G SLA'ed 10Mbit service with static IP, and I get a Cat 5 ethernet down from it.
So all I did, was to go my "interface FastEthernet4", and typed
ip address 173.243.123.123 255.255.255.252.
Changed speed to "speed 100" and "full-duplex" (as instructed by the ISP).
I also did "ip default-gateway 173.243.123.124", which is the default gate way assigned by the ISP.
I also typed "ip name-server 64.17.123.123" to setup the new DNS, am I doing anything wrong?  I can't even use the router to ping google, but if I connect the laptop directly to the outside line, then it works, so I know the outside line is good.
Am I not doing something right?  Why can't I connect to the internet?  I wasted several hours already trying everything in my book to trouble shoot a supposedly very simple configuration change.  Do I need to change something related to NAT when changing to Static IP?  My NAT was working just fine before when under DHCP.
Thanks for the help!
The below is my full config (some IPs changed to preserve anonymity):
Building configuration...
Current configuration : 16628 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname PureGate
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 51200 informational
enable secret 5 adsfasdf
enable password 7 asdfasdfdasf
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
clock timezone PCTime -8
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-1245995727
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1245995727
revocation-check none
rsakeypair TP-self-signed-1245995727
crypto pki trustpoint test_trustpoint_config_created_for_sdm
subject-name e=sdmtest@sdmtest.com
revocation-check crl
crypto pki certificate chain TP-self-signed-1234213421342134
certificate self-signed 01
  adsfasdfadfasdfasdfasf
  quit
crypto pki certificate chain test_trustpoint_config_created_for_sdm
no ip source-route
ip dhcp pool ccp-pool1
   import all
   network 10.2.2.0 255.255.255.0
   default-router 10.2.2.1
   dns-server 10.2.2.1
   domain-name local
ip dhcp update dns
ip cef
ip domain name local
ip host local ns ns.local
ip host trac.local 10.2.2.7
ip host ns.local 10.2.2.1
ip host-list members.dyndns.org
ip host-list mydomain.dyndns.org
ip name-server 64.17.123.124
ip name-server 4.2.2.1
ip ddns update method ccp_ddns
HTTP
  add http://mydomain:passwd@members.dyndns.org/nic/update?system=dyndns&hostname=passwd@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
  remove http://mydomain:passwd@members.dyndns.org/nic/update?system=dyndns&hostname=passwd@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
interval maximum 28 0 0 0
interval minimum 28 0 0 0
ip dhcp-client update dns server both
parameter-map type regex ccp-regex-nonascii
pattern [^\x00-\x80]
parameter-map type protocol-info msn-servers
server name messenger.hotmail.com
server name gateway.messenger.hotmail.com
server name webmessenger.msn.com
parameter-map type protocol-info aol-servers
server name login.oscar.aol.com
server name toc.oscar.aol.com
server name oam-d09a.blue.aol.com
parameter-map type protocol-info yahoo-servers
server name scs.msg.yahoo.com
server name scsa.msg.yahoo.com
server name scsb.msg.yahoo.com
server name scsc.msg.yahoo.com
server name scsd.msg.yahoo.com
server name cs16.msg.dcn.yahoo.com
server name cs19.msg.dcn.yahoo.com
server name cs42.msg.dcn.yahoo.com
server name cs53.msg.dcn.yahoo.com
server name cs54.msg.dcn.yahoo.com
server name ads1.vip.scd.yahoo.com
server name radio1.launch.vip.dal.yahoo.com
server name in1.msg.vip.re2.yahoo.com
server name data1.my.vip.sc5.yahoo.com
server name address1.pim.vip.mud.yahoo.com
server name edit.messenger.yahoo.com
server name messenger.yahoo.com
server name http.pager.yahoo.com
server name privacy.yahoo.com
server name csa.yahoo.com
server name csb.yahoo.com
server name csc.yahoo.com
username admin privilege 15 secret 5 asdfasdfasdfas
username user2 privilege 15 secret 5 adsfasdfasdfas
crypto logging ezvpn
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration address-pool local SDM_POOL_1
crypto isakmp client configuration group Company
key sdfgsdfgdsgsd
dns 4.2.2.1 4.2.2.2
pool SDM_POOL_1
acl 102
include-local-lan
max-users 100
netmask 255.255.255.0
banner ^CWelcome to company VPN!  Split tunneling is enabled.        ^C
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
set security-association idle-time 3600
set transform-set ESP-3DES-SHA
set isakmp-profile ciscocp-ike-profile-1
crypto ctcp port 10000
archive
log config
  hidekeys
ip tcp synwait-time 10
class-map type inspect match-any SDM_HTTPS
match access-group name SDM_HTTPS
class-map type inspect match-any SDM_SSH
match access-group name SDM_SSH
class-map type inspect match-any SDM_SHELL
match access-group name SDM_SHELL
class-map type inspect match-any sdm-cls-access
match class-map SDM_HTTPS
match class-map SDM_SSH
match class-map SDM_SHELL
class-map type inspect imap match-any ccp-app-imap
match  invalid-command
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
class-map type inspect match-any CCP-Voice-permit
match protocol h323
match protocol skinny
match protocol sip
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any SDM_IP
match access-group name SDM_IP
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
class-map type inspect match-any SDM_EASY_VPN_SERVER_TRAFFIC
match protocol isakmp
match protocol ipsec-msft
match class-map SDM_AH
match class-map SDM_ESP
class-map type inspect match-all SDM_EASY_VPN_SERVER_PT
match class-map SDM_EASY_VPN_SERVER_TRAFFIC
class-map type inspect ymsgr match-any ccp-app-yahoo-otherservices
match  service any
class-map type inspect msnmsgr match-any ccp-app-msn-otherservices
match  service any
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-cls-protocol-im
match protocol ymsgr yahoo-servers
match protocol msnmsgr msn-servers
match protocol aol aol-servers
class-map type inspect aol match-any ccp-app-aol-otherservices
match  service any
class-map type inspect match-all ccp-protocol-pop3
match protocol pop3
class-map type inspect pop3 match-any ccp-app-pop3
class-map type inspect match-all sdm-access
match class-map sdm-cls-access
match access-group 101
match  service text-chat
class-map type inspect match-all ccp-protocol-im
match class-map ccp-cls-protocol-im
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect http match-any ccp-app-httpmethods
match  request method bcopy
match  request method bdelete
match  request method bmove
match  request method bpropfind
match  request method bproppatch
match  request method connect
match  request method copy
match  request method delete
match  request method edit
match  request method getattribute
match  request method getattributenames
match  request method getproperties
match  request method index
match  request method lock
match  request method mkcol
match  request method mkdir
match  request method move
match  request method notify
match  request method options
match  request method poll
match  request method propfind
match  request method proppatch
match  request method put
match  request method revadd
match  request method revlabel
match  request method revlog
match  request method revnum
match  request method save
match  request method search
match  request method setattribute
match  request method startrev
match  request method stoprev
match  request method subscribe
match  request method trace
match  request method unedit
match  request method unlock
match  request method unsubscribe
class-map type inspect http match-any ccp-http-blockparam
match  request port-misuse im
match  request port-misuse p2p
match  req-resp protocol-violation
class-map type inspect match-all ccp-protocol-imap
match protocol imap
class-map type inspect match-all ccp-protocol-http
match protocol http
class-map type inspect http match-any ccp-http-allowparam
match  request port-misuse tunneling
interface Null0
no ip unreachables
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
ip dhcp client update dns server none
ip ddns update hostname members.dyndns.org
ip ddns update ccp_ddns1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
ip nat enable
ip virtual-reassembly
speed 100
full-duplex
interface Virtual-Template1 type tunnel
ip unnumbered Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 10.2.2.1 255.255.255.0
no ip redirects
no ip unreachables
ip flow ingress
ip flow egress
ip nat inside
ip tcp adjust-mss 1452
ip local pool SDM_POOL_1 10.2.2.100 10.2.2.254
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-top-talkers
top 100
sort-by bytes
cache-timeout 1000
ip dns server
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 10.0.0.12 80 interface FastEthernet4 999
ip access-list extended DYNDNS
permit tcp host 204.13.248.112 eq 443 any established log
ip access-list extended SDM_AH
remark CCP_ACL Category=1
permit ahp any any
ip access-list extended SDM_ESP
permit esp any any
ip access-list extended SDM_HTTPS
permit tcp any any eq 443
ip access-list extended SDM_IP
permit ip any any
ip access-list extended SDM_SHELL
permit tcp any any eq cmd
ip access-list extended SDM_SSH
permit tcp any any eq 22
ip access-list extended VNC
permit tcp any any eq 999
ip access-list extended kwVNC
remark kwVNC
permit tcp any host 10.0.0.19 eq 999
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 permit 10.2.2.0 0.0.0.255
access-list 2 permit 10.0.0.20
access-list 2 remark CCP_ACL Category=1
access-list 2 permit 10.0.0.21
access-list 3 remark CCP_ACL Category=1
access-list 3 permit 10.0.0.11
access-list 3 permit 10.0.0.15
access-list 4 remark CCP_ACL Category=1
access-list 4 permit 10.0.0.14
access-list 4 permit 10.0.0.16
access-list 10 remark CCP_ACL Category=16
access-list 10 permit 10.0.0.19
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark CCP_ACL Category=128
access-list 101 permit ip any any
access-list 102 remark CCP_ACL Category=4
access-list 102 permit ip 10.2.2.0 0.0.0.255 any
no cdp run
control-plane
banner exec ^C
29 Replies 29
root@dev-server:~$ ping 4.2.2.1
PING 4.2.2.1 (4.2.2.1) 56(84) bytes of data.
From 10.2.2.1 icmp_seq=1 Destination Net Unreachable
So your router( default gw) can't reach this destination.  can you do a show ip route 4.2.2.1 on your router
Regards.
Alain.
Hi Alain,
My router can ping the internet fine, just not my linux box which is behind the router.
PureGate#ping 4.2.2.1
Sending 5, 100-byte ICMP Echos to 4.2.2.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/22/28 ms
The strange thing is, all the windows boxes were okay, the mac boxes were having stability issues until I took out the "import all" from the dhcp pool  below.
   import all                     <----  REMOVED, helped with mac laptop's internet stability issues.
   default-router 10.2.2.1    <-- Regarding the default-router, should I put in the router's IP address or the default gateway from the ISP?
   dns-server 10.2.2.1        <-- same question, should I use the router as a dns server, or use the ISP's dns server?
   domain-name local
Is anything in this dhcp pool above not setup correctly so that linux boxes cannot receive dhcp properly?
Also, I tried "debug ip dhcp server event", and then did a renewal of the DHCP lease on the linux server, but I don't see any debug messages on the Cisco router.
Kuangwei
Kuangwei
for default-router : you must put the router ip address  because this is the default gw your machines will use and it must be in the same subnet as the hosts
for dns-server: you can give ip of ISP dns server or the router but then you must configure your router as a caching router.
No looking at this pool config there is nothing unusual. and your ping proves this box was using the good default-router
Could you post the entire running as well as output from ip config of windows and linux
Regards.
Alain.
Hello Alain,
Here is my entire running config, I really appreciate the help.  I have also attached the ipconfig /all of the windows laptop I am using (internet working), and the ifconfig -a of the linux server (internet not working) as well as the routing table for both.
Kuangwei
========= Cisco 861 router ==============
Current configuration : 16638 bytes
! Last configuration change at 12:06:11 PCTime Mon Jan 24 2011 by admin
! NVRAM config last updated at 12:06:28 PCTime Mon Jan 24 2011 by admin
version 12.4
no service pad
hostname PureGate
boot-start-marker
boot-end-marker
enable secret 5 asdfasdf
aaa new-model
crypto pki trustpoint TP-self-signed-1341234
subject-name cn=IOS-Self-Signed-Certificate-1234234
rsakeypair TP-self-signed-12341234
crypto pki certificate chain TP-self-signed-asdfasdf
  aasdfasdfasdf
  quit
no ip source-route
   dns-server 64.17.248.2
   domain-name local
ip dhcp update dns
ip cef
ip host-list company.dyndns.org
ip name-server 64.17.248.2
ip name-server 69.38.208.20
ip name-server 64.17.248.20
ip ddns update method ccp_ddns1
HTTP
  add http://company:password@members.dyndns.org/nic/update?system=dyndns&hostname=password@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=
  remove http://company:password@members.dyndns.org/nic/update?system=dyndns&hostname=password@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=
username admin privilege 15 secret 5 adsfasdfa
encr 3des
group 2
key adsfsdfasdf
dns 4.2.2.1 4.2.2.2
pool SDM_POOL_1
acl 102
include-local-lan
max-users 100
banner ^CWelcome to Company VPN!  Split tunneling is enabled.      ^C
crypto isakmp profile ciscocp-ike-profile-1
   match identity group Comapny
   client authentication list ciscocp_vpn_xauth_ml_1
   isakmp authorization list ciscocp_vpn_group_ml_1
   client configuration address respond
   virtual-template 1
archive
log config
  hidekeys
match protocol h323
match protocol sip
match protocol dns
match protocol ftp
match protocol h323
match protocol icmp
match protocol imap
match protocol pop3
match  service any
match  service any
match protocol icmp
match protocol tcp
match protocol udp
match  service any
match protocol pop3
match protocol imap
match protocol http
interface Null0
no ip unreachables
ip address 173.243.149.226 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
ip nat enable
speed 100
full-duplex
ip unnumbered Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
interface Vlan1
no ip redirects
no ip unreachables
ip flow ingress
ip flow egress
ip nat inside
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip http server
ip flow-top-talkers
top 100
sort-by bytes
cache-timeout 1000
ip dns server
ip dns primary local soa ns.local kwh@pureconduit.com 21600 900 7776000 86400
ip nat inside source static tcp 10.0.0.10 24669 interface FastEthernet4 24669
ip access-list extended IansBittorrent
remark CCP_ACL Category=256
remark Ian's bittorrent
permit tcp host 10.0.0.222 eq www any eq www
permit ahp any any
permit esp any any
permit ip any any
remark kwVNC
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you
want to use.
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
exec-timeout 0 0
no modem enable
transport output telnet
line aux 0
line vty 0 4
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
========= Linux ifconfig  (internet doens't work) =================
root@dev-server:~$ ifconfig -a
eth0      Link encap:Ethernet  HWaddr 00:26:b9:89:64:de
          inet addr:10.2.2.7  Bcast:10.2.2.255  Mask:255.255.255.0
          inet6 addr: fe80::226:b9ff:fe89:64de/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:2635 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1024 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:597543 (597.5 KB)  TX bytes:450490 (450.4 KB)
          Interrupt:16 Memory:da000000-da012800
eth1      Link encap:Ethernet  HWaddr 00:26:b9:89:64:df
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:17 Memory:dc000000-dc012800
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:154 errors:0 dropped:0 overruns:0 frame:0
          TX packets:154 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:113695 (113.6 KB)  TX bytes:113695 (113.6 KB)
========= Linux routing table (internet doesn't work) ============
root@dev-server:~$ netstat -nr
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
10.2.2.0        0.0.0.0         255.255.255.0   U         0 0          0 eth0
169.254.0.0     0.0.0.0         255.255.0.0     U         0 0          0 eth0
0.0.0.0         10.2.2.1        0.0.0.0         UG        0 0          0 eth0
========= Windows ipconfig (Internet Works) ===============
C:\Users\developer>ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : developer-THINK
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : local
Wireless LAN adapter Wireless Network Connection:
   Connection-specific DNS Suffix  . : local
   Description . . . . . . . . . . . : Intel(R) Centrino(R) Advanced-N 6200 AGN
   Physical Address. . . . . . . . . : 58-94-6B-4A-CC-20
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::84f4:4abf:f1ba:3f75%13(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.2.2.4(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Monday, January 24, 2011 11:00:17 AM
   Lease Expires . . . . . . . . . . : Monday, January 24, 2011 2:44:00 PM
   Default Gateway . . . . . . . . . : 10.2.2.1
                                       173.243.149.225
   DHCP Server . . . . . . . . . . . : 255.255.255.255
   DHCPv6 IAID . . . . . . . . . . . : 324572267
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-14-8F-24-77-F0-DE-F1-2F-76-59
   DNS Servers . . . . . . . . . . . : 64.17.248.2
   NetBIOS over Tcpip. . . . . . . . : Enabled
========= Windows routing table (Internet Works) ============
C:\Users\developer>route print
Interface List
13...58 94 6b 4a cc 20 ......Intel(R) Centrino(R) Advanced-N 6200 AGN
11...f0 de f1 2f 76 59 ......Intel(R) 82577LM Gigabit Network Connection
  1...........................Software Loopback Interface 1
12...00 00 00 00 00 00 00 e0 Microsoft 6to4 Adapter
18...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
14...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
34...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0         10.2.2.1         10.2.2.4     25
          0.0.0.0          0.0.0.0  173.243.149.225         10.2.2.4     25
         10.2.2.0    255.255.255.0         On-link          10.2.2.4    281
         10.2.2.1  255.255.255.255         On-link          10.2.2.4     26
         10.2.2.4  255.255.255.255         On-link          10.2.2.4    281
       10.2.2.255  255.255.255.255         On-link          10.2.2.4    281
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    306
        224.0.0.0        240.0.0.0         On-link          10.2.2.4    281
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    306
  255.255.255.255  255.255.255.255         On-link          10.2.2.4    281
Persistent Routes:
  None
IPv6 Route Table
Active Routes:
If Metric Network Destination      Gateway
14     58 ::/0                     On-link
  1    306 ::1/128                  On-link
14     58 2001::/32                On-link
14    306 2001:0:4137:9e76:189a:37e4:f5fd:fdfb/128
                                    On-link
13    281 fe80::/64                On-link
14    306 fe80::/64                On-link
14    306 fe80::189a:37e4:f5fd:fdfb/128
                                    On-link
13    281 fe80::84f4:4abf:f1ba:3f75/128
                                    On-link
  1    306 ff00::/8                 On-link
14    306 ff00::/8                 On-link
13    281 ff00::/8                 On-link
Persistent Routes:
  None
I'm gonna take a look at it tomorrow.
Regards.
Alain.
Still not having any luck, another piece of information on tracepath (Ubuntu version of tracert):
root@dev-server:/etc/dhcp3$ tracepath 4.2.2.1
1:  dev-server.local (10.2.2.7)                    0.130ms pmtu 1500
1:  10.2.2.1 (10.2.2.1)                                    0.685ms !N
1:  10.2.2.1 (10.2.2.1)                                    0.643ms !N
     Resume: pmtu 1500
I don't see anything in the config that should provoke the symptom you have.
Can you sniff on linux box when pinging( and the same on windows) and also provide output of arp cache on linux box, windows and on the router( sh ip arp).
Regards.
Alain.
I've had the same issue with a ubuntu box, basically is was holding onto the old default gateway or didn't apply it.
Basically  change the network setting for the ubuntu box from DHCP to manual and enter some setting sucj as 192.168.1.1 255.255.255.0 def gateway 192.168.1.1, accept this  and it will apply your entered settings, then go back in and clear them  all off then change it to DHCP ( clear all the settings first ) and then apply those setting and your  box should pick up the new or changed default gateway.
Hi Ian, could you go into a bit more specifics on what you did to fix it?
I changed to static IP assignment (did an ip dhcp excluded-address for an address range), and have the Linux server assign a static IP, dns, default gateway (10.2.2.1) for itself, subnet 255.255.255.0.  After rebooting, it still can't ping the internet (ping 4.2.2.1).
However, in the morning when I came back into the office, I was able to ping 4.2.2.1!  I thought about your response and thought maybe now the gateway has "unstuck" itself from the previous configuration, and I set it back to DHCP, took out the DHCP excluded address range, and restarted the network interface on the ubuntu box.  However, now I can't ping 4..2.2.1 anymore.  I tried rebooting as well, doesn't work.  I tried changing it back to Static IP, doesn't work either, reboot doesn't work either.  Quite frustrating problem. =(
It was a test lab I had and I changed the default gate address on a router, and had
to ammend the DHCP. When I done this the ubuntu box had a new IP in the correct subnet but couldn't ping
a remote router or access the internet.
From the Ubuntu box, I removed all DHCP setting and set the nic to manual and manually entered a new IP address, subnet mask and default gateway, I then applied this to the box.
I then went back in and cleared these setting so that the IP address, Subnet mask and default gateway where blank. I may have hit ok and tried to apply these, I then went back in and made sure all setting where blank set the nic to DHCP applied and all worked.
The issue was on the ubuntu box for me, it just kept hold of the old default gateway for some strange reason.
So after serveral reboots on the Ubuntu box as DHCP, I converted it back to static IP.  When that didn't work, I hard rebooted the Cisco router, and that fixed it, now I am able to connect to the internet on the Linux box.  Since the Linux box is in a production environment, I will keep it running on static IP for now.  I have saved all my configs and server settings in the case this DHCP issue need to be revisited in the future.
Thanks all again for help.
Hi Alain,
I am not sure what tool to use for sniffing the Linux box (can you let me know?), but I can show you the arp cache now:
Linux box:
root@dev-server:~$ arp -n
Address                  HWtype  HWaddress           Flags Mask            Iface
10.2.2.33                ether   5c:ac:4c:bf:b6:0f   C                     eth0
10.2.2.55                ether   c8:bc:c8:ea:d4:0c   C                     eth0
10.2.2.1                 ether   30:46:9a:a1:a1:1c   C                     eth0
10.2.2.4                 ether   58:94:6b:4a:cc:20   C                     eth0
routing table:
root@dev-server:~$ route -n
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
169.254.0.0     0.0.0.0         255.255.0.0     U     1000   0        0 eth0
0.0.0.0         10.2.2.1        0.0.0.0         UG    100    0        0 eth0
Windows:
C:\Users\khwang>arp -a
Interface: 10.2.2.4 --- 0xd
  Internet Address      Physical Address      Type
  10.2.2.1              c4-7d-4f-16-33-58     dynamic
  10.2.2.6              58-94-6b-47-c9-10     dynamic
  10.2.2.7              00-26-b9-89-64-de     dynamic
  10.2.2.24             5c-ac-4c-bd-42-5e     dynamic
  10.2.2.33             5c-ac-4c-bf-b6-0f     dynamic
  10.2.2.40             5c-ac-4c-bd-01-32     dynamic
  10.2.2.43             1c-c1-de-12-37-42     dynamic
  10.2.2.44             00-26-ab-54-9d-91     dynamic
  10.2.2.45             5c-ac-4c-bd-42-5a     dynamic
  10.2.2.47             c0-cb-38-44-ed-47     dynamic
  10.2.2.49             00-26-bb-0e-cb-5c     dynamic
  10.2.2.54             00-26-bb-0e-cb-5c     dynamic
  10.2.2.55             c8-bc-c8-ea-d4-0c     dynamic
  10.2.2.255            ff-ff-ff-ff-ff-ff     static
  224.0.0.22            01-00-5e-00-00-16     static
  224.0.0.251           01-00-5e-00-00-fb     static
  224.0.0.252           01-00-5e-00-00-fc     static
  239.255.255.250       01-00-5e-7f-ff-fa     static
  255.255.255.255       ff-ff-ff-ff-ff-ff     static
Router:  The arp cache here is too large to show, there are 10+ ppl  working at the company right now and this is a production router:
PureGate#show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  1.36.3.168             46   0016.c7eb.ff5f  ARPA   FastEthernet4
Internet  1.160.25.171           28   0016.c7eb.ff5f  ARPA   FastEthernet4
Internet  1.160.194.38           51   0016.c7eb.ff5f  ARPA   FastEthernet4
Internet  4.2.2.1                58   0016.c7eb.ff5f  ARPA   FastEthernet4
Internet  4.255.67.151           38   0016.c7eb.ff5f  ARPA   FastEthernet4
Internet  10.0.0.4               65   0016.c7eb.ff5f  ARPA   FastEthernet4
Internet  10.2.2.1                -   c47d.4f16.3358  ARPA   Vlan1
Internet  10.2.2.4                0   5894.6b4a.cc20  ARPA   Vlan1
Internet  10.2.2.6                0   5894.6b47.c910  ARPA   Vlan1
Internet  10.2.2.7               33   0026.b989.64de  ARPA   Vlan1
Internet  10.2.2.23             125   dc2b.618e.7d13  ARPA   Vlan1
Internet  10.2.2.24               0   5cac.4cbd.425e  ARPA   Vlan1
Internet  10.2.2.25             106   24ab.8178.49f2  ARPA   Vlan1
Internet  10.2.2.26              95   40a6.d92f.c2a8  ARPA   Vlan1
Internet  10.2.2.28              18   5cac.4cbf.3e30  ARPA   Vlan1
Internet  10.2.2.33               0   5cac.4cbf.b60f  ARPA   Vlan1
Internet  10.2.2.34             106   40a6.d930.b60d  ARPA   Vlan1
Internet  10.2.2.35              92   40a6.d999.a6f6  ARPA   Vlan1
Internet  10.2.2.38               1   001c.26c8.33b5  ARPA   Vlan1
Internet  10.2.2.40               0   5cac.4cbd.0132  ARPA   Vlan1
Internet  10.2.2.41             111   5894.6b48.2f54  ARPA   Vlan1
Internet  10.2.2.42              13   581f.aa65.8710  ARPA   Vlan1
Internet  10.2.2.43             130   1cc1.de12.3742  ARPA   Vlan1
Internet  10.2.2.44               0   0026.ab54.9d91  ARPA   Vlan1
Internet  10.2.2.45               0   5cac.4cbd.425a  ARPA   Vlan1
Internet  10.2.2.46              43   c8bc.c8ea.d40c  ARPA   Vlan1
Internet  10.2.2.47               0   c0cb.3844.ed47  ARPA   Vlan1
Internet  10.2.2.48             186   904c.e541.9256  ARPA   Vlan1
Internet  10.2.2.49              72   0026.bb0e.cb5c  ARPA   Vlan1
Internet  10.2.2.50              29   24ab.8178.49f2  ARPA   Vlan1
Internet  10.2.2.51               3   40a6.d930.b60d  ARPA   Vlan1
Internet  10.2.2.52               1   40a6.d92f.c2a8  ARPA   Vlan1
Internet  10.2.2.53               8   40a6.d999.a6f6  ARPA   Vlan1
Internet  10.2.2.54              17   0026.bb0e.cb5c  ARPA   Vlan1
Internet  10.2.2.55              13   c8bc.c8ea.d40c  ARPA   Vlan1
Internet  12.129.210.71          13   0016.c7eb.ff5f  ARPA   FastEthernet4
Internet  12.130.81.249           8   0016.c7eb.ff5f  ARPA   FastEthernet4
Internet  12.187.155.101         40   0016.c7eb.ff5f  ARPA   FastEthernet4
Internet  15.193.112.23          17   0016.c7eb.ff5f  ARPA   FastEthernet4
Internet  15.201.49.21           18   0016.c7eb.ff5f  ARPA   FastEthernet4
Internet  15.217.8.105           55   0016.c7eb.ff5f  ARPA   FastEthernet4
Internet  15.217.120.21          18   0016.c7eb.ff5f  ARPA   FastEthernet4
Internet  15.240.238.53          72   0016.c7eb.ff5f  ARPA   FastEthernet4
Internet  17.149.36.114          72   0016.c7eb.ff5f  ARPA   FastEthernet4
Internet  17.151.16.21           72   0016.c7eb.ff5f  ARPA   FastEthernet4
Internet  17.151.16.23           73   0016.c7eb.ff5f  ARPA   FastEthernet4
--More--
I was able to briefly pring 4.2.2.1 this morning from the Linux dev box, but not anymore now.  We really need to get to the bottom of this for this production environment.
Thanks!
Kuangwei
to sniff traffic on linux bow use tcpdump.
Looking at your arp caches you haven't got the same mapping for 10.2.2.1 on linux and windows.
On windows the MAC is the MAC address of the Cisco router but on the linux box it corresponds to a netgear box.
Regards.
Alain.
Oh wow, you are right!  The previous gateway was a netgear, I guess that arp cache got stuck in there.  How do you properly clear the arp cache on a linux box to ensure this doesn't happen again?
Thanks again for root causing this.
Cheers,
Kuangwei
arp -d 10.2.2.1 should do the trick.
Regards.
Alain.
