cisco 867vae bridge telstra bigpond config refuses to work
Bigmalloy
Hello
I have attempted to make a working config that used the 867vae as a bridge so my router can get served a dhcp internet address from a telstra adsl2+ connection. My connection used to require PPPoe login from my router to the bridged modem, but now it just requires dhcp, this is an upgrade apparently my credentials are automatically worked out by my phone number and no longer requiring PPPoe. I have tested this with other bridged modems and it works great just bridge modem as per usual and select dhcp instead of pppoe on the router to fire it up.
I have tried many cobbled together configs but nothing works, I notice most of the con figs I try for this router do not turn on the dsl modem and see no sync light hence the line wan mode dsl is added, many also contain the line control-plane which is an unrecognized command, any help would be much appreciated.
My closest guess at a working config
wan mode dsl
! controller VDSL 0 operating mode adsl2+ ! no ip route-cache ! interface atm0 no shut no ip address no ip directed-broadcast no atm ilmi-keepalive pvc 8/35 encapsulation aal5snap bridge-group 11 ! vlan 11 ! interface Ethernet0 description TELSTRA TBIZ no ip address bridge-group 11 ! interface FastEthernet0 description UPLINK TO WAN ROUTER switchport access vlan 11 no ip address ! interface Vlan11 description BRIDGE INTERFACE FOR WAN ROUTER no ip address bridge-group 11 ! bridge 11 protocol ieee bridge crb
ok heres the working config I noticed when I was trying your suggestion that the command
no ip route-cache
came up as an error and changed it to
no ip routing
then it WORKED ! thanks for your help see below for a working config.
You plug your router into fastEthernet port0 and phone line in the correct port.
You should be able to uses PPPoe or in my case DHCP
wan mode dsl
no ip routing
no ip cef
no ipv6 cef
controller VDSL 0
bridge crb
interface ATM0
 no ip address
 no ip route-cache
 bridge-group 11
 pvc 8/35
interface Ethernet0
 no ip address
 no ip route-cache
 shutdown
 bridge-group 11
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
interface Vlan1
 no ip address
 no ip route-cache
interface Vlan11
 no ip address
 no ip route-cache
 bridge-group 11
ip forward-protocol nd
no ip http server
no ip http secure-server
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
 transport input none
scheduler allocate 60000 1000
johnd2310
Level 8
Level 8
Have you tried the following:
interface BVI11
ip address dhcp
John
**Please rate posts you find helpful**
no ip route-cache
no ip routing
wan mode dsl
no ip routing
no ip cef
no ipv6 cef
controller VDSL 0
bridge crb
interface ATM0
 no ip address
 no ip route-cache
 bridge-group 11
 pvc 8/35
interface Ethernet0
 no ip address
 no ip route-cache
 shutdown
 bridge-group 11
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
interface Vlan1
 no ip address
 no ip route-cache
interface Vlan11
 no ip address
 no ip route-cache
 bridge-group 11
no ip http server
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
